I don’t understand why my atom echo don’t work with assist…
It does not appear to be connected.
Here it is connected.
ESPHome is connected to it but it is not connected to Home Assistant:
Ok. How can i solve this issue?
Check the logs lin ESPHome (the LOGS button in your last image). Paste the text here, not a screenshot.
INFO ESPHome 2023.11.6
INFO Reading configuration /config/esphome/m5stack-atom-echo-8564e8.yaml...
INFO Updating https://github.com/esphome/esphome.git@pull/5230/head
INFO Starting log output from m5stack-atom-echo-8564e8.local using esphome API
INFO Successfully connected to m5stack-atom-echo-8564e8 in 2.434s
INFO Successful handshake with m5stack-atom-echo-8564e8 in 0.240s
[13:04:40][I][app:102]: ESPHome version 2023.11.6 compiled on Nov 29 2023, 11:44:37
[13:04:40][I][app:104]: Project m5stack.atom-echo-voice-assistant version 1.0
[13:04:40][C][wifi:559]: WiFi:
[13:04:40][C][wifi:391]: Local MAC: 50:02:91:85:64:E8
[13:04:40][C][wifi:396]: SSID: [redacted]
[13:04:40][C][wifi:397]: IP Address: 10.0.0.120
[13:04:40][C][wifi:399]: BSSID: [redacted]
[13:04:40][C][wifi:400]: Hostname: 'm5stack-atom-echo-8564e8'
[13:04:40][C][wifi:402]: Signal strength: -53 dB ▂▄▆█
[13:04:40][C][wifi:406]: Channel: 1
[13:04:40][C][wifi:407]: Subnet: 255.255.255.0
[13:04:40][C][wifi:408]: Gateway: 10.0.0.1
[13:04:40][C][wifi:409]: DNS1: 1.1.1.1
[13:04:40][C][wifi:410]: DNS2: 8.8.8.8
[13:04:40][C][esp32_ble_server:200]: ESP32 BLE Server:
[13:04:47][D][voice_assistant:529]: Event Type: 0
[13:04:47][D][light:036]: 'M5Stack Atom Echo 8564e8' Setting:
[13:04:47][D][light:051]: Brightness: 60%
[13:04:47][D][light:059]: Red: 100%, Green: 89%, Blue: 71%
[13:04:47][I][ota:117]: Boot seems successful, resetting boot loop counter.
[13:04:47][D][esp32.preferences:114]: Saving 1 preferences to flash...
[13:04:47][D][esp32.preferences:143]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
[13:04:55][D][voice_assistant:189]: VAD detected speech
[13:04:55][D][voice_assistant:422]: State changed from WAITING_FOR_VAD to START_PIPELINE
[13:04:55][D][voice_assistant:428]: Desired state set to STREAMING_MICROPHONE
[13:04:55][D][voice_assistant:206]: Requesting start...
[13:04:55][D][voice_assistant:422]: State changed from START_PIPELINE to STARTING_PIPELINE
[13:04:55][D][voice_assistant:443]: Client started, streaming microphone
[13:04:55][D][voice_assistant:422]: State changed from STARTING_PIPELINE to STREAMING_MICROPHONE
[13:04:55][D][voice_assistant:529]: Event Type: 1
[13:04:55][D][voice_assistant:532]: Assist Pipeline running
[13:04:55][D][voice_assistant:529]: Event Type: 9
[13:05:05][D][voice_assistant:529]: Event Type: 0
[13:05:05][D][voice_assistant:529]: Event Type: 2
[13:05:05][D][voice_assistant:189]: VAD detected speech
[13:05:05][D][voice_assistant:422]: State changed from WAITING_FOR_VAD to START_PIPELINE
[13:05:05][D][voice_assistant:443]: Client started, streaming microphone
[13:05:05][D][voice_assistant:422]: State changed from STARTING_PIPELINE to STREAMING_MICROPHONE
[13:05:05][D][voice_assistant:428]: Desired state set to STREAMING_MICROPHONE
[13:05:05][D][voice_assistant:529]: Event Type: 1
[13:05:05][D][voice_assistant:532]: Assist Pipeline running
[13:05:05][D][voice_assistant:529]: Event Type: 9
[13:05:13][D][voice_assistant:529]: Event Type: 0
[13:05:13][D][voice_assistant:529]: Event Type: 2
[13:05:13][D][voice_assistant:619]: Assist Pipeline ended
[13:05:13][D][voice_assistant:422]: State changed from STREAMING_MICROPHONE to WAIT_FOR_VAD
[13:05:13][D][voice_assistant:189]: VAD detected speech
[13:05:13][D][light:036]: 'M5Stack Atom Echo 8564e8' Setting:
[13:05:13][D][light:051]: Brightness: 60%
[13:05:13][D][voice_assistant:443]: Client started, streaming microphone
[13:05:13][D][voice_assistant:422]: State changed from STARTING_PIPELINE to STREAMING_MICROPHONE
[13:05:13][D][voice_assistant:428]: Desired state set to STREAMING_MICROPHONE
[13:05:13][D][voice_assistant:529]: Event Type: 1
[13:05:13][D][voice_assistant:532]: Assist Pipeline running
[13:05:13][D][voice_assistant:529]: Event Type: 9
[13:05:24][D][voice_assistant:529]: Event Type: 0
[13:05:24][D][voice_assistant:529]: Event Type: 2
[13:05:24][D][voice_assistant:619]: Assist Pipeline ended
[13:05:24][D][voice_assistant:422]: State changed from STREAMING_MICROPHONE to WAIT_FOR_VAD
[13:05:24][D][voice_assistant:189]: VAD detected speech
[13:05:24][D][voice_assistant:422]: State changed from WAITING_FOR_VAD to START_PIPELINE
[13:05:24][D][light:051]: Brightness: 60%
[13:05:24][D][voice_assistant:443]: Client started, streaming microphone
[13:05:24][D][voice_assistant:422]: State changed from STARTING_PIPELINE to STREAMING_MICROPHONE
[13:05:24][D][voice_assistant:428]: Desired state set to STREAMING_MICROPHONE
[13:05:24][D][voice_assistant:529]: Event Type: 1
[13:05:24][D][voice_assistant:532]: Assist Pipeline running
[13:05:24][D][voice_assistant:529]: Event Type: 9
[13:05:33][D][voice_assistant:529]: Event Type: 0
[13:05:33][D][voice_assistant:529]: Event Type: 2
[13:05:33][D][voice_assistant:189]: VAD detected speech
[13:05:33][D][voice_assistant:422]: State changed from WAITING_FOR_VAD to START_PIPELINE
[13:05:33][D][voice_assistant:443]: Client started, streaming microphone
[13:05:33][D][voice_assistant:422]: State changed from STARTING_PIPELINE to STREAMING_MICROPHONE
[13:05:33][D][voice_assistant:428]: Desired state set to STREAMING_MICROPHONE
[13:05:33][D][voice_assistant:529]: Event Type: 1
[13:05:33][D][voice_assistant:532]: Assist Pipeline running
[13:05:33][D][voice_assistant:529]: Event Type: 9
[13:05:44][D][voice_assistant:529]: Event Type: 0
[13:05:44][D][voice_assistant:206]: Requesting start...
[13:05:44][D][voice_assistant:422]: State changed from START_PIPELINE to STARTING_PIPELINE
[13:05:44][D][voice_assistant:443]: Client started, streaming microphone
[13:05:44][D][voice_assistant:422]: State changed from STARTING_PIPELINE to STREAMING_MICROPHONE
[13:05:44][D][voice_assistant:428]: Desired state set to STREAMING_MICROPHONE
[13:05:44][D][voice_assistant:529]: Event Type: 1
[13:05:44][D][voice_assistant:532]: Assist Pipeline running
[13:05:44][D][voice_assistant:529]: Event Type: 9
[13:05:57][D][voice_assistant:529]: Event Type: 0
[13:05:58][D][voice_assistant:529]: Event Type: 2
[13:05:58][D][voice_assistant:619]: Assist Pipeline ended
[13:05:58][D][voice_assistant:189]: VAD detected speech
[13:05:58][D][voice_assistant:443]: Client started, streaming microphone
[13:05:58][D][voice_assistant:422]: State changed from STARTING_PIPELINE to STREAMING_MICROPHONE
[13:05:58][D][voice_assistant:428]: Desired state set to STREAMING_MICROPHONE
[13:05:58][D][voice_assistant:529]: Event Type: 1
[13:05:58][D][voice_assistant:532]: Assist Pipeline running
[13:05:58][D][voice_assistant:529]: Event Type: 9
[13:06:08][D][voice_assistant:529]: Event Type: 0
[13:06:08][D][voice_assistant:529]: Event Type: 2
[13:06:08][D][voice_assistant:619]: Assist Pipeline ended
[13:06:08][D][voice_assistant:176]: Waiting for speech...
[13:06:08][D][voice_assistant:422]: State changed from WAIT_FOR_VAD to WAITING_FOR_VAD
[13:06:08][D][voice_assistant:443]: Client started, streaming microphone
[13:06:08][D][voice_assistant:422]: State changed from STARTING_PIPELINE to STREAMING_MICROPHONE
[13:06:08][D][voice_assistant:428]: Desired state set to STREAMING_MICROPHONE
[13:06:08][D][voice_assistant:529]: Event Type: 1
[13:06:08][D][voice_assistant:532]: Assist Pipeline running
[13:06:08][D][voice_assistant:529]: Event Type: 9
