So I held the reset button and then reinstalled it by directly plugging it into the server and then updated it and it works but it didn’t require an API line to add it for some reason. Idk. It works now but the audio crackles and doesn’t work right. It’ll respond to a command slowly like it’s lagging. And then my home assistant will restart usually.
This looked like a failure due to resources. Probably RAM. That’s why I asked. You still didn’t tell us, so it will remain a mystery. Glad you solved it though.
