When i press the button the blue light turns on but after speaking and releasing the button the light turns to red, searched the forum and internet, but didn’t find a solutions.
I just figured out why it didn’t work for me. I had the Atom Echo on different VLAN than the HA server and the communication was somehow blocked by firewall rules. I just moved it to my main LAN and it finally works.
All my ESPHOME devices work fine from a separate VLAN but for some reason Echo Atom didn’t.
So when I hit the button, it starts red for 1 sec. then BLUE until I release it and it starts to flash/blink BLUE for 30 sec. and ends with red for 1 sec.
Again I have the same error as in the Topic mentioned.
I see the logbook is telling me it is working on it; 30 sec. later it stops.
So the log is not telling me much other then that the Assistant sensor is busy. So please let someone explain what am I doing to resolve this. Thanks.
Are you using the built-in commands?
Have you exposed the required entities?
Does the command work if you type it in on the assist communication dialog? (Three dots on top right side of dashboard)
Logger: homeassistant.components.assist_pipeline.pipeline
Source: components/esphome/voice_assistant.py:147
Integration: Assist pipeline (documentation, issues)
First occurred: 5:22:43 AM (1 occurrences)
Last logged: 5:22:43 AM
Unexpected error during speech-to-text
File "/usr/src/homeassistant/homeassistant/components/assist_pipeline/pipeline.py", line 447, in speech_to_text
result = await self.stt_provider.async_process_audio_stream(
File "/usr/src/homeassistant/homeassistant/components/cloud/stt.py", line 92, in async_process_audio_stream
result = await self.cloud.voice.process_stt(
File "/usr/local/lib/python3.11/site-packages/hass_nabucasa/voice.py", line 1262, in process_stt
async with self.cloud.websession.post(
File "/usr/local/lib/python3.11/site-packages/aiohttp/client.py", line 1141, in __aenter__
self._resp = await self._coro
File "/usr/local/lib/python3.11/site-packages/aiohttp/client.py", line 560, in _request
await resp.start(conn)
File "/usr/local/lib/python3.11/site-packages/aiohttp/client_reqrep.py", line 899, in start
message, payload = await protocol.read() # type: ignore[union-attr]
File "/usr/local/lib/python3.11/site-packages/aiohttp/streams.py", line 616, in read
await self._waiter
File "/usr/local/lib/python3.11/site-packages/aiohttp/client_reqrep.py", line 581, in write_bytes
await self.body.write(writer)
File "/usr/local/lib/python3.11/site-packages/aiohttp/payload.py", line 443, in write
chunk = await self._iter.__anext__()
File "/usr/src/homeassistant/homeassistant/components/esphome/voice_assistant.py", line 147, in _iterate_packets
raise RuntimeError("Not running")
RuntimeError: Not running
followed by this one a few miliseconds later:
Logger: homeassistant.components.cloud.stt
Source: components/cloud/stt.py:98
Integration: Home Assistant Cloud (documentation, issues)
First occurred: 5:22:48 AM (1 occurrences)
Last logged: 5:22:48 AM
Voice error: Error processing en-GB speech: 400 No audio data received
@scorpio862 or @Damaar : Before I crack open Wireshark, did either of you figure out what firewall or NAT rule was necessary to allow the STT pipeline?
@shbatm , would love to see your wireshark results. I did a bit of digging in Wake word is rolled out? - #33 by Lakini and ran into the issue of some access points just blocking UDP traffic after a while or if the number of packages per time gets too high…
Has anyone managed to figure this out?
Running into the same issue… I can use assist from the browser no problems, but get the stt-stream-failed error using the Atom Echo.
In my case it’s a networking issue, to test this i installed pfSense on a VM to act as my router and my ESPhome assistants started to work. Unfortunately my little home server is not powerful enough to host pfSense so i had to revert to my old situation with things not working. When i figure out what the issue is I will report back here.
Thank you for this tip! I just about gave up on using these devices because of this issue. For now I’m happy to use them on my main LAN if it means I can actually use it. I switched over both the media player and voice assistant versions are working!
