Hi i installed esphome locally via usb, adopted into home assistant and uploaded firmware ok
it shows up ok in ha but i get following error in logs…
[07:07:11][D][api:102]: Accepted 192.168.13.18
[07:07:11][W][api.connection:107]: : Reading failed: BAD_INDICATOR errno=11
my config …
substitutions:
friendly_name: AtomEcho
esphome:
friendly_name: ${friendly_name}
min_version: 2024.6.0
name_add_mac_suffix: false
project:
version: dev
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
# Allow Over-The-Air updates
ota:
- platform: esphome
# Allow provisioning Wi-Fi via serial
improv_serial:
wifi:
# Set up a wifi access point
ap: {}
domain: ""
manual_ip:
static_ip: 192.168.13.107
gateway: 192.168.13.1
subnet: 255.255.255.0
dns1: 192.168.13.1
# In combination with the `ap` this allows the user
# to provision wifi credentials to the device via WiFi AP.
captive_portal:
dashboard_import:
package_import_url: github://esphome/example-configs/esphome-web/esp32.yaml@main
import_full_config: true
# Sets up Bluetooth LE (Only on ESP32) to allow the user
# to provision wifi credentials to the device.
esp32_improv:
authorizer: none
# To have a "next url" for improv serial
web_server:
