Is this possible?
I want to speak a command to the atom echo, and have it’s reply spoken out on a snapcast speaker (which is another media_player entity), instead on the not so good speaker on the echo itself.
Is this possible?
I wish.
Though I’m sure many people using voice are having this issue, so it’s likely the devs will focus on it soon enough.
This has been added to ESPHome:
speaker
above.Cool, thanks!
I just updated to: Firmware: 2023.11.1 (Nov 16 2023, 12:21:59)
But I still don’t see the option in my settings? I’m a bit of an ESPHome noob, do I need to configure the media_player during compile time in the atom-echo yaml?
Here’s the yaml:
substitutions:
friendly_name: Atom Echo Living Room
packages:
m5stack.atom-echo-voice-assistant: github://esphome/firmware/voice-assistant/m5stack-atom-echo.yaml@main
esphome:
name_add_mac_suffix: false
friendly_name: ${friendly_name}
api:
encryption:
key: [redacted]
wifi:
ssid: !secret wifi_ssid
Yes you would need to alter the source yaml file to include a media player and to use that option instead of the speaker option. Which as I have just discovered is a problem. I can’t see any way to bring a home assistant media player into ESPHome.
So still not possible as far as I can see.
There’s an ESPHome discord server that may know more.
