Atom Echo works for a while after restart, but then stops responding
Did a ton more debugging and long-term testing. I found that disabling the captive portal and re-enabling the high perf network resulted in more stability.
The biggest boost to stability seemed to be disabling all references to switching between the on-device wakeword and wakeword available in HA. To be clear, this config now hardcodes the device to using the wakeword in HA, with no option to change it.
The latest config now looks like this:
esphome:
  friendly_name: echo
esp32:
  board: m5stack-atom
  cpu_frequency: 240MHz
  framework:
    type: esp-idf
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: ""
ota:
  - platform: esphome
    password: ""
wifi:
  ssid: !secret wifi_ssid
#captive_portal:
#network:
#  enable_high_performance: false
button:
  - platform: factory_reset
i2s_audio:
  - id: i2s_audio_bus
    i2s_lrclk_pin: GPIO33
    i2s_bclk_pin: GPIO19
microphone:
  - platform: i2s_audio
    i2s_din_pin: GPIO23
    adc_type: external
    pdm: true
    sample_rate: 16000
    correct_dc_offset: true
speaker:
    i2s_dout_pin: GPIO22
    dac_type: external
    bits_per_sample: 16bit
    sample_rate: 16000
    channel: right
    buffer_duration: 240ms
media_player:
  - platform: speaker
    announcement_pipeline:
      speaker: echo_speaker
      format: WAV
      num_channels: 1
    codec_support_enabled: false
    buffer_size: 6000
    volume_min: 0.4
    files:
      - id: timer_finished_wave_file
        file: https://github.com/esphome/wake-word-voice-assistants/raw/main/sounds/timer_finished.wav
    on_announcement:
      - if:
            - microphone.is_capturing:
          then:
            - script.execute: stop_wake_word
      - light.turn_on:
          blue: 100%
          red: 0%
          green: 0%
          brightness: 100%
          effect: none
    on_idle:
      - script.execute: start_wake_word
      - script.execute: reset_led
voice_assistant:
  microphone:
    microphone: echo_microphone
    channels: 0
    gain_factor: 4
  media_player: echo_media_player
  noise_suppression_level: 2
  auto_gain: 31dBFS
  on_listening:
    - light.turn_on:
        blue: 100%
        red: 0%
        green: 0%
        effect: "Slow Pulse"
  on_stt_vad_end:
    - light.turn_on:
        blue: 100%
        red: 0%
        green: 0%
        effect: "Fast Pulse"
  on_tts_start:
    - light.turn_on:
        blue: 100%
        red: 0%
        green: 0%
        brightness: 100%
        effect: none
  on_start:
    - logger.log: Voice Assistant started!
    - script.execute: track_idle_stream
  on_end:
    # Handle the "nevermind" case where there is no announcement
    - wait_until:
          - media_player.is_announcing:
        #timeout: 0.5s
        timeout: 2s
    - logger.log: Voice Assistant ended!
  on_error:
    - light.turn_on:
        red: 100%
        green: 0%
        blue: 0%
        brightness: 100%
        effect: none
    - delay: 2s
  on_client_connected:
    - delay: 2s  # Give the api server time to settle
  on_client_disconnected:
  on_timer_finished:
    - wait_until:
        not:
    - switch.turn_on: timer_ringing
    - light.turn_on:
        red: 0%
        green: 100%
        blue: 0%
        brightness: 100%
    - wait_until:
        - switch.is_off: timer_ringing
    - light.turn_off: led
    - switch.turn_off: timer_ringing
binary_sensor:
  # button does the following:
  # short click - stop a timer
  # if no timer then restart either microwakeword or voice assistant continuous
  - platform: gpio
    pin:
      number: GPIO39
      inverted: true
    disabled_by_default: true
    entity_category: diagnostic
    on_multi_click:
      - timing:
          - ON for at least 50ms
          - OFF for at least 50ms
        then:
          - if:
                switch.is_on: timer_ringing
              then:
              else:
      - timing:
          - ON for at least 10s
        then:
          - button.press: factory_reset_btn
light:
  - platform: esp32_rmt_led_strip
    entity_category: config
    pin: GPIO27
    default_transition_length: 0s
    chipset: SK6812
    num_leds: 1
    rgb_order: grb
    effects:
      - pulse:
          transition_length: 250ms
          update_interval: 250ms
          min_brightness: 50%
          max_brightness: 100%
      - pulse:
          transition_length: 100ms
          update_interval: 100ms
          min_brightness: 50%
script:
  - id: reset_led
    then:
      - if:
            - switch.is_on: use_listen_light
          then:
            - light.turn_on:
                red: 0%
                green: 100%
                blue: 100%
                brightness: 60%
                effect: none
          else:
  - id: start_wake_word
    then:
    - lambda: id(va).set_use_wake_word(true);
    - voice_assistant.start_continuous:
  - id: stop_wake_word
    then:
    - lambda: id(va).set_use_wake_word(false);
    - voice_assistant.stop:
  # Work around https://github.com/home-assistant/core/issues/149882.
  - id: track_idle_stream
    mode: restart
    then:
      - delay: 180s
      - logger.log: Restarting continuous recognition to avoid HA issue 149882
      - wait_until:
            - not: {voice_assistant.is_running:}
      - delay: 1s
switch:
    name: Use listen light
    optimistic: true
    restore_mode: RESTORE_DEFAULT_ON
    on_turn_on:
    on_turn_off:
    optimistic: true
    restore_mode: ALWAYS_OFF
    on_turn_off:
      # Turn off the repeat mode and disable the pause between playlist items
      - lambda: |-
              id(echo_media_player)
                ->make_call()
                .set_command(media_player::MediaPlayerCommand::MEDIA_PLAYER_COMMAND_REPEAT_OFF)
                .set_announcement(true)
                .perform();
              id(echo_media_player)->set_playlist_delay_ms(speaker::AudioPipelineType::ANNOUNCEMENT, 0);
      # Stop playing the alarm
      - media_player.stop:
          announcement: true
    on_turn_on:
      # Turn on the repeat mode and pause for 1000 ms between playlist items/repeats
      - lambda: |-
              ->make_call()
              .set_command(media_player::MediaPlayerCommand::MEDIA_PLAYER_COMMAND_REPEAT_ONE)
              .perform();
            id(echo_media_player)->set_playlist_delay_ms(speaker::AudioPipelineType::ANNOUNCEMENT, 1000);
      - media_player.speaker.play_on_device_media_file:
          media_file: timer_finished_wave_file
          announcement: true
      - delay: 15min
