Atome Linky : refresh issue
Since last update of HA I noticed a refresh problem with Linky’s Atom key. Indeed, after 2 hours of normal use, the refreshing stops and you must systematically restart Home Assistant to obtain a connection.
Missing last value in values: {'message': 'Login failed'}: 'total'
Is anyone in the same situation?
Thank you
Yes, i have the same issue !!
Same issue here.
Using the latest 2021.11.0 version
It could be a security from the API maintainer…
I’ve seen that live info is fetched every 30 seconds… Maybe a security is locking the request because of too many requests…
By the way, if I’m doing a manual pyatome request on another device (other connection also), the request is performing well… So it’s not related the the Atome account itself…
indeed, still the same with core-2021.11.0…
maybe a solution very soon Atome key stops updating after 2 hours - githubmemory
by jugla
I post a pull request to solve the issue in HomeAssistant (https://github.com/home-assistant/core/pull/60955).
Meanwhile, you can use keyatome in HACS (https://github.com/jugla/keyatome)
