I installed Atomic Calendar Revive but it is not showing up as an option when I add a card. The instructions to install are for previous version of HACS but isn’t complicated for HACS 2.0 unless I missed something easy. This is what I have tried to troubleshoot in no particular order and have done multiple times:
- Cleared cache
- Redownloaded Integration
- Restarted Home Assistant
- Confirmed the resource file exists.
- Add card manually
Also, I have a device called Atomic Calendar Revive.
Google Calendar is installed correctly because I can use the default Calendar Card.
Installed:
Atomic Calendar 10.0.0
I am not sure what next steps are in troubleshooting. Any suggestions?
