lsaranto
(Lasse)
August 17, 2022, 8:12am
1
I’m having a problem with motion notifications from Frigate. I receive the notifications, but way too often the attached image(s) isn’t included in the message.
I’m using Gmail and Telegram broadcast to send the notifications. I’ve looked at the automation and script traces, but I can’t find any differences between the notifications that include the image and the ones that don’t. Also, if I copy the service call and its parameters from the trace and input them into the Service call tool, the notifications always go through fine.
I thought that maybe the image file isn’t written yet when the automation tries to read it. So I added delays, but it hasn’t changed anything. I’ve also added a check that reads the Frigate event data to check that there is a snapshot available.
I’m not posting any yaml (yet) as I can’t see how it could have any errors, since sometimes the same yaml code(s) works.
crzynik
(Nicolas Mowen)
August 17, 2022, 12:44pm
2
Seeing the automation yaml is a must otherwise it is just guessing, seeing how it is working can give clues on the intermittent behavior.
lsaranto
(Lasse)
August 17, 2022, 2:54pm
3
Alrighty then, Here is the automation:
alias: Send notification when Frigate detects an object
description: ''
- platform: mqtt
topic: frigate/events
condition: []
- condition: template
value_template: >-
{{ ( now().timestamp() -
as_timestamp(states('input_datetime.last_piha_notification'), 0) ) >
(10*60) }}
- service: script.turn_on
entity_id: >-
script.send_{{ trigger.payload_json["after"]["camera"]
}}_camera_motion_notification
variables:
event_data: '{{ trigger.payload }}'
camera: '{{ trigger.payload_json["after"]["camera"] }}'
label: '{{ trigger.payload_json["after"]["label"] }}'
title: >-
Havaittu liikettä {{ trigger.payload_json["after"]["camera"] ~
"-kamerassa" }}
message: >-
"-kamerassa -- " ~ trigger.payload_json["after"]["start_time"] |
timestamp_custom('%d.%m.%Y %H:%M') }}
url: >-
http://192.168.10.50:5000/api/events/{{
trigger.payload_json["after"]["id"] }}/thumbnail.jpg
path: >-
/media/frigate/clips/{{ trigger.payload_json["after"]["camera"] ~ "-"
path2: >-
caption: >-
{{ trigger.payload_json["after"]["camera"] ~ "-kamera -- " ~
- service: input_datetime.set_datetime
entity_id: >-
input_datetime.last_{{ trigger.payload_json["after"]["camera"]
}}_notification
timestamp: '{{ now().timestamp() }}'
enabled: false
trace:
stored_traces: 5
mode: single
Here’s the script:
alias: Send piha camera motion notification
sequence:
- if:
value_template: event_data["after"]["has_snapshot"] == false
then:
- delay:
hours: 0
minutes: 5
seconds: 0
milliseconds: 0
else:
- delay:
hours: 0
minutes: 0
seconds: 15
milliseconds: 0
entity_id: input_datetime.last_piha_notification
- service: script.send_motion_notification_to_telegrams
data_template:
title: '{{title}}'
message: '{{message}}'
path: '{{path}}'
caption: '{{caption}}'
- service: script.send_motion_notifications_to_emails
data_template:
title: '{{title}}'
path: '{{path}}'
path2: '{{path2}}'
mode: restart
Here’s the Telegram script:
alias: Send motion notification to Telegrams
sequence:
- choose:
- conditions:
- condition: state
entity_id: input_boolean.lasse_telegram
state: 'on'
sequence:
- service: notify.lasse_telegram
data_template:
title: '{{ title }}'
message: '{{ message }}'
photo:
- file: '{{ path }}'
default: []
mode: queued
max: 5
And the email script:
alias: Send motion notifications to emails
sequence:
- choose:
- conditions:
- condition: state
entity_id: input_boolean.kaija_email
state: 'on'
sequence:
- service: notify.kaija_email
message: ''
images:
- '{{ path }}'
- '{{ path2 }}'
html: >
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html lang="en" xmlns="http://www.w3.org/1999/xhtml"> <head>
<meta charset="UTF-8">
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
</head> <body>
<p>{{ message }}</p>
<p>Tunnistettu kohde:<br>
<img src="cid:{{ path.split('/')|last }}" /></p>
<p>Koko kuva:<br>
<img src="cid:{{ path2.split('/')|last }}" width="720" /></p>
</body> </html>
default: []
- choose:
- conditions:
- condition: state
entity_id: input_boolean.lasse_email
state: 'on'
sequence:
- service: notify.lasse_email
message: ''
images:
- '{{ path }}'
- '{{ path2 }}'
html: >
</head> <body>
<p>Koko kuva:<br>
</body> </html>
default: []
- choose:
- conditions:
- condition: state
entity_id: input_boolean.risto_email
state: 'on'
sequence:
- service: notify.risto_email
message: ''
images:
- '{{ path }}'
- '{{ path2 }}'
html: >
</head> <body>
<p>Koko kuva:<br>
</body> </html>
default: []
mode: single
