Attaching photo to persistent notification
I am trying to figure out how to attach a photo to a persistent notification. I would like to send a notification when my front door camera detects a person with an image attached.
I have it working but for some reason it always sends the same photo. It’s like it is cached somewhere and doesn’t update the image even though a new image has been created.
Here’s the code that creates the snapshot:
metadata: {}
  filename: /config/www/images/front_door/front-door-person.jpg
  entity_id: camera.doorbell_clear
action: camera.snapshot
Running that creates this image (note the time: 08:26):
When I run this:
alias: Send a notification
action: notify.persistent_notification
  message: >-
    Person Detected<p> ![Front Door
    Motion](/local/images/front_door/front-door-person.jpg)
  title: Front Door
It always sends this file (note time: 08:14):
If I obtain the link from the image in the notification it displays the old file until I refresh the browser then it shows the correct updated photo.
Is there a way to send the updated file via the notification?
I’d like the file to overwrite so I only have the last version of the photo only.
Thanks in advance.
Did you ever get this figured out. I am seeing the same thing
Can’t say I have.
I figured out the .jpg name needs to be unique for them to display right in the HA App/Web UI. I couldn’t get the variables to work in an automation from one command to another, so I went with a script which stores the file name in a helper, then call that script in the automation. I have setup a bunch of them and works significantly better than the DVR software alone, given the data I have in HA to work with.
I am using this in a script to take the snapshot:
alias: Snapshot-Mailbox
sequence:
  - variables:
      timestamp: "{{ now().strftime('%Y%m%d_%H%M%S') }}"
      snapshot_filename: snapshot_uvc_front_door_{{ timestamp }}.jpg
      snapshot_path: /config/www/tmp/{{ snapshot_filename }}
  - data:
      value: "{{ snapshot_filename }}"
      entity_id: input_text.snapshot_mailbox_filename
    action: input_text.set_value
  - data:
      filename: "{{ snapshot_path }}"
      entity_id: camera.uvc_front_door_high_resolution_channel_insecure
  - wait_template: >-
      {{ snapshot_filename in
      state_attr('camera.uvc_front_door_high_resolution_channel_insecure',
      'entity_picture') }}
    timeout: "00:00:01"
mode: single
Then the action part of the automation:
actions:
  - choose:
      - conditions:
          - condition: trigger
            id:
              - OPEN
              - CLOSED
              - ERROR
              - NOT-UPDATING
        sequence:
          - action: script.snapshot_mailbox
            data: {}
          - delay:
              hours: 0
              minutes: 0
              seconds: 1
              milliseconds: 0
          - data:
              title: |-
                Mailbox - {% if is_state('binary_sensor.mailbox_door', 'off') %}CLOSED
                         {% elif is_state('binary_sensor.mailbox_door', 'on') %} OPENED
                         {% else %} UNKNOWN {% endif %}
              message: |-
                {{ now().strftime("%m-%d-%Y - %r") }}
                Battery: **{{ states('sensor.mailbox_battery') }}%**
                Signal: **{{ states('sensor.mailbox_signal_strength') }} dBm**
                Status: {% if is_state('binary_sensor.mailbox_door', 'off') %} **Closed**
                        {% elif is_state('binary_sensor.mailbox_door', 'on') %} **Open**
                        {% else %} **Unknown** {% endif %}
                ![image](/local/tmp/{{
                states('input_text.snapshot_mailbox_filename') }})
                [Link](/config/devices/device/6ea919d6417bc8ffd735fd9df31f0589)
          - data:
              title: |-
                Mailbox - {% if is_state('binary_sensor.mailbox_door', 'off') %} CLOSED
              message: |-
                Status: {% if is_state('binary_sensor.mailbox_door', 'off') %} Closed
                        {% elif is_state('binary_sensor.mailbox_door', 'on') %} Opened
                        {% else %} Unknown {% endif %}
                  content-type: jpeg
                  url: |-
                    /local/tmp/{{ states('input_text.snapshot_mailbox_filename') }}
            action: notify.mobile_app_joes_iphone
          - action: shell_command.delete_camera_snapshots
            metadata: {}
            data: {}
mode: single
Figured out that the Snapshots have to stay around until you view them in the App/Web GUI. So I do it on every run:
# Delete snapshots older than 7 days
  delete_camera_snapshots: "find /config/www/tmp -name '*.jpg' -mtime +7 -delete"
Thanks for posting that. I will certainly be giving this a go. Thanks again :+1:.
Thanks for the info, here is my code / version of your script / automation. I decided that I’d write the file name to a text help from within the automation. Hopefully that will work.
alias: Doorbell Person or Button Pressed
description: >-
  Triggers when a person is detected or the doorbell button is pressed. Takes a
  snapshot, announces, and sends a notification.
triggers:
  - entity_id: binary_sensor.doorbell_person
    to: "on"
    trigger: state
  - entity_id: binary_sensor.doorbell_visitor
    to: "on"
    trigger: state
conditions:
  - condition: state
    state: "off"
    for: "00:02:00"
    enabled: true
  - condition: state
    state: "off"
    for: "00:02:00"
    enabled: true
actions:
  - if:
      - condition: or
        conditions:
          - condition: sun
            after: sunset
            after_offset: "-00:15:00"
          - condition: sun
            before: sunrise
            before_offset: "00:15:00"
    then:
      - action: light.turn_on
        metadata: {}
          brightness_pct: 100
          entity_id:
            - light.porch_2
            - light.porch_led
      - wait_for_trigger:
          - entity_id:
              - binary_sensor.doorbell_person
              - binary_sensor.doorbell_visitor
            to: "off"
            for: "00:05:00"
            trigger: state
      - target:
          entity_id:
            - light.porch
            - light.porch_led
        action: light.turn_off
        data: {}
    alias: Turn on the porch lights if dark
  - alias: Set snapshot filename
    metadata: {}
      value: doorbell_{{ now().strftime('%d%m%Y_%H%M%S') }}.jpg
      entity_id: input_text.doorbell_snapshot
  - alias: Take a snapshot
      filename: >-
        /config/www/images/front_door/{{
        (states("input_text.doorbell_snapshot")) }}
      entity_id: camera.doorbell_fluent
  - metadata: {}
      announcement: Someone is at the front door
    alias: Announce that someone is at the front door
    action: script.play_an_announcement_speaker_selection
  - delay: "00:00:02"
  - data:
      title: Front Door Alert
      message: Someone is at the front door.
          content-type: jpeg
          url: >-
            /local/images/front_door/{{ (states("input_text.doorbell_snapshot"))
    action: notify.mobile_app_steves_iphone
    alias: Send a notification to Steve's phone
  - alias: Turn off the porch lights if dark and they are on
    if:
      - condition: or
        conditions:
          - condition: sun
            after: sunset
          - condition: sun
            before: sunrise
          - condition: state
            entity_id: light.porch_2
            state: "on"
          - condition: state
            entity_id: light.porch_led
            state: "on"
    then:
      - wait_for_trigger:
          - entity_id:
            to: "off"
            for: "00:05:00"
            trigger: state
        timeout:
          hours: 0
          minutes: 5
          seconds: 30
          milliseconds: 0
        alias: Wait until the doorbell goes clear for 5 minutes
      - target:
          entity_id:
            - light.porch
            - light.porch_led
        data: {}
  - action: shell_command.purge_doorbell_snapshots
    metadata: {}
    data: {}
    alias: Purge old snapshots (> 1 week)
mode: single
The only issue I am having is that I don’t see an image when I click on the notification on my iPhone. I can see an image on my apple watch and when the notification is received but when I click on it, the home assistant app opens but no image is presented. Is there something I am overlooking?
Thanks again for your advice.
I had the same issue, I couldn’t get the variables to work in an automation, that’s why I moved them to the script.
Using
filename: /config/www/tmp/snapshot_uvc_front_door_{{ timestamp }}.jpg Created
I do see your URL is double quoted vs single, not sure if that matters:
url: /local/tmp/{{ states(‘input_text.snapshot_bar_filename’) }}
Did you check the input_text value matches the actual file name in created in /local/images/?
I moved the commands from the script to the automation and this is working:
alias: Notify - Mailbox
description: ""
triggers:
  - trigger: state
    entity_id:
      - binary_sensor.mailbox_door
    to: "on"
    alias: Mailbox Opened
  - alias: Mailbox Closed
    trigger: state
    entity_id:
    to: "off"
  - value_template: >-
      {{ now() - states.binary_sensor.mailbox_door.last_changed >=
      timedelta(days=3) }}
    trigger: template
    alias: Mailbox Not Updating
  - trigger: numeric_state
    entity_id:
      - sensor.mailbox_battery
    below: 50
    alias: Mailbox Battery Low
conditions: []
actions:
  - choose:
      - conditions:
            id:
              - OPEN
              - CLOSED
        sequence:
          - action: input_text.set_value
            metadata: {}
              value: snapshot_mailbox_{{ now().strftime('%Y%m%d_%H%M%S') }}
          - action: camera.snapshot
            metadata: {}
              filename: >-
                /config/www/tmp/{{
          - delay:
              hours: 0
              minutes: 0
              seconds: 1
              milliseconds: 0
          - data:
              title: >-
                CLOSED
              message: >-
                {%- from 'relative_time_plus.jinja' import relative_time_plus %}
                Updated: **{{
                relative_time_plus(states.binary_sensor.mailbox_door.last_changed,3)
                **Closed**{% elif is_state('binary_sensor.mailbox_door', 'on')
                %} **Open**{% else %}**Unknown**{% endif %}
          - data:
              title: >-
                CLOSED
              message: >-
                Battery: {{ states('sensor.mailbox_battery') }}%
                Signal: {{ states('sensor.mailbox_signal_strength') }} dBm
                Updated: {{
                Closed{% elif is_state('binary_sensor.mailbox_door', 'on') %}
                Opened{% else %} Unknown{% endif %}
                  content-type: jpeg
                  url: >-
            metadata: {}
            data: {}
      - conditions:
            id:
              - NOT-UPDATING
              - BATTERY
        sequence:
          - data:
              title: Mailbox - ERROR
              message: >-
                Updated: **{{
                %} **Opened**{% else %} **Unknown**{% endif %}
          - data:
              message: >-
                Updated: {{
                url: /config/devices/device/6ea919d6417bc8ffd735fd9df31f0589
mode: single
