Dear community and potential saviors
I’ve spent a great deal of time trying to get this to work on my own without success. Hopefully someone can assist me!
I have read the relevant home assistant docs and all related manuals from Fibaro (along with a long thread with their support), yet i cannot manage to get one FGD212 Dimmer 2 to control another.
My environment is a Debian 10 VM running Home Assistant 2021.1.3 in VENV Python 3.7.3 with an AEON Labs ZW090 Z-Stick Gen5+ controller. The integration used is the regular zwave intergration (I plan on migrating to zwavejs in the future!).
Wiring
I have added all FGD212 Dimmer 2s in none secure mode and I have confirmed they are neighbors.
Named as following in Home Assistant/Z-wave integration
1 Master Bedroom WiC LED (Node 36)
2 Master Bedroom WiC Bollampa (Node 35)
3 Master Bedroom WiC (Node 25)
My goal is for Node 25 to control node 35 and 36.
My first approach was to group them together using Node group associations. I tried groups 2-5 without success.
This is the output in OWZ.log when i press S1
2021-02-09 12:34:55.305 Detail, Node025, Refreshed Value: old value=0, new value=1, type=list
2021-02-09 12:34:55.305 Detail, Node025, Changes to this value are not verified
2021-02-09 12:34:55.305 Info, Node025, Received Configuration report: Parameter=13, Value=1
2021-02-09 12:34:55.305 Detail, Node025, Notification: ValueChanged
2021-02-09 12:34:56.377 Detail, Node025, Received: 0x01, 0x0d, 0x00, 0x04, 0x00, 0x19, 0x05, 0x70, 0x06, 0x0d, 0x01, 0x00, 0xca, 0x00, 0x5a
2021-02-09 12:34:56.378 Detail,
2021-02-09 12:34:56.378 Detail, Node025, Refreshed Value: old value=1, new value=0, type=list
2021-02-09 12:34:56.378 Detail, Node025, Changes to this value are not verified
2021-02-09 12:34:56.378 Info, Node025, Received Configuration report: Parameter=13, Value=0
2021-02-09 12:34:56.378 Detail, Node025, Notification: ValueChanged
Fibaro support suggested i use scene activation
I set the following in the z-wave integration
Output of log when i click set configuration parameter
2021-02-09 12:39:39.370 Info, Node025, Sending (Send) message (Callback ID=0x39, Expected Reply=0x13) - ConfigurationCmd_Set (Node=25): 0x01, 0x0c, 0x00, 0x13, 0x19, 0x05, 0x70, 0x04, 0x1c, 0x01, 0x01, 0x25, 0x39, 0x88
2021-02-09 12:39:39.378 Detail, Node025, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2021-02-09 12:39:39.378 Detail, Node025, ZW_SEND_DATA delivered to Z-Wave stack
2021-02-09 12:39:39.441 Detail, Node025, Received: 0x01, 0x18, 0x00, 0x13, 0x39, 0x00, 0x00, 0x06, 0x02, 0xc9, 0x7f, 0x7f, 0x7f, 0x7f, 0x00, 0x00, 0x03, 0x0f, 0x05, 0x00, 0x00, 0x03, 0x01, 0x00, 0x00, 0x0b
2021-02-09 12:39:39.441 Detail, Node025, ZW_SEND_DATA Request with callback ID 0x39 received (expected 0x39)
2021-02-09 12:39:39.441 Info, Node025, Request RTT 71 Average Request RTT 1566
2021-02-09 12:39:39.441 Detail, Expected callbackId was received
2021-02-09 12:39:39.441 Detail, Expected reply was received
2021-02-09 12:39:39.441 Detail, Message transaction complete
2021-02-09 12:39:39.441 Detail, Node025, Removing current message
2021-02-09 12:39:39.441 Info, Node025, Sending (Send) message (Callback ID=0x3a, Expected Reply=0x04) - ConfigurationCmd_Get (Node=25): 0x01, 0x0a, 0x00, 0x13, 0x19, 0x03, 0x70, 0x05, 0x1c, 0x25, 0x3a, 0x8a
2021-02-09 12:39:39.450 Detail, Node025, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2021-02-09 12:39:39.450 Detail, Node025, ZW_SEND_DATA delivered to Z-Wave stack
2021-02-09 12:39:39.516 Detail, Node025, Received: 0x01, 0x18, 0x00, 0x13, 0x3a, 0x00, 0x00, 0x07, 0x02, 0xc9, 0x7f, 0x7f, 0x7f, 0x7f, 0x00, 0x00, 0x03, 0x0f, 0x05, 0x00, 0x00, 0x03, 0x01, 0x00, 0x00, 0x09
2021-02-09 12:39:39.516 Detail, Node025, ZW_SEND_DATA Request with callback ID 0x3a received (expected 0x3a)
2021-02-09 12:39:39.516 Info, Node025, Request RTT 74 Average Request RTT 820
2021-02-09 12:39:39.516 Detail, Expected callbackId was received
2021-02-09 12:39:39.584 Detail, Node025, Received: 0x01, 0x0d, 0x00, 0x04, 0x00, 0x19, 0x05, 0x70, 0x06, 0x1c, 0x01, 0x01, 0xc9, 0x00, 0x49
2021-02-09 12:39:39.584 Info, Node025, Response RTT 142 Average Response RTT 2936
2021-02-09 12:39:39.584 Detail, Node025, Refreshed Value: old value=1, new value=1, type=list
2021-02-09 12:39:39.584 Detail, Node025, Changes to this value are not verified
2021-02-09 12:39:39.584 Info, Node025, Received Configuration report: Parameter=28, Value=1
2021-02-09 12:39:39.584 Detail, Node025, Expected reply and command class was received
2021-02-09 12:39:39.584 Detail, Node025, Message transaction complete
2021-02-09 12:39:39.584 Detail, Node025, Removing current message
2021-02-09 12:39:39.584 Detail, Node025, Notification: ValueChanged
After that i go to automations in the UI and create an empty automation. I enter a trigger for an event and enter the following as event data
event_data:
entity_id: zwave.master_bedroom_wic
scene_id: 16
UI returns Message malformed: Integration not found
I go to developer tools and Listen to events where I enter zwave.scene_activated. No output when i press S1 like a madman.
I’m a novice when it comes to HA, it is not unlikely i have made multiple simple mistakes. Thank you for reading my post and a BIG thanks in advance to anyone who can offer guidance.
