Attempt to integrate everHome using an api
I am using a Home Assistant installation on my RPI in my room. My father, on the other hand, uses this system. Now the developers have released an API to integrate other systems. This is described here. Now my question…how can I configure this in Home Assistant, unfortunately I lack the knowledge.
Of course we switched to the beta version as described in the everhome forum. I have already tried a little with the REST integrations, however, I have not come to any result. A tip would therefore be very helpful.
With kind regards
Is there already a solution how to integrate that?
what is the status on this issue?
is there already a solution?
Find here the link to the german discord channel form Daniel, who made a awesome working Node-Red integration of everhome to Homeassistant:
Hi, here you can find a Everhome Ecotracker integration to Homeassistent.
https://github.com/Selbstbau-PV/Ecotracker-Daten-im-Home-Assistant-anzeigen
So you can use the Ecotracker as Grid Smartmeter in HA.
