Have configured an automation based on “state” of an LG TV, and conditioned by an attribute “source” value, but, if I edit the automation, or reboot HA while the device is “off” the “attribute” in “conditions” is lost.
Tried to reconfigure that same condition while the device if OFF and cannot find the respective “attribute”, but, I can see all attributes listed.
Haven’t tried yet, but I’m convinced this wouldn’t be an issue is using the “automations.yaml”, it may only affect those automations configured using the UI.
From memory, do not believe this was an issue a few versions back!
My understanding is that this comes from the integration… the dropdowns populate based on what is supplied by the integration. If an attribute isn’t supplied when the device is in a certain state, it won’t show up in the State tool or be populated in dropdowns.
You can always manually type the attribute’s name into the field whether it’s currently available or not.
