When shutting Home Assistant down, I have the following error in the log:
2022-06-15 09:40:11 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/srv/homeassistant/lib/python3.9/site-packages/homeassistant/helpers/storage.py", line 256, in _async_callback_final_write
await self._async_handle_write_data()
File "/srv/homeassistant/lib/python3.9/site-packages/homeassistant/helpers/storage.py", line 276, in _async_handle_write_data
await self.hass.async_add_executor_job(
File "/usr/lib/python3.9/concurrent/futures/thread.py", line 52, in run
File "/srv/homeassistant/lib/python3.9/site-packages/homeassistant/helpers/storage.py", line 287, in _write_data
json_util.save_json(
File "/srv/homeassistant/lib/python3.9/site-packages/homeassistant/util/json.py", line 59, in save_json
json_data = json.dumps(data, indent=4, cls=encoder)
File "/usr/lib/python3.9/json/__init__.py", line 234, in dumps
return cls(
File "/usr/lib/python3.9/json/encoder.py", line 201, in encode
chunks = list(chunks)
File "/usr/lib/python3.9/json/encoder.py", line 431, in _iterencode
yield from _iterencode_dict(o, _current_indent_level)
File "/usr/lib/python3.9/json/encoder.py", line 405, in _iterencode_dict
yield from chunks
yield from chunks
File "/usr/lib/python3.9/json/encoder.py", line 325, in _iterencode_list
yield from chunks
File "/usr/lib/python3.9/json/encoder.py", line 439, in _iterencode
yield from _iterencode(o, _current_indent_level)
yield from chunks
yield from chunks
yield from chunks
yield from chunks
yield from chunks
yield from chunks
File "/usr/lib/python3.9/json/encoder.py", line 438, in _iterencode
o = _default(o)
File "/srv/homeassistant/lib/python3.9/site-packages/homeassistant/helpers/json.py", line 40, in default
return super().default(o)
File "/srv/homeassistant/lib/python3.9/site-packages/homeassistant/helpers/json.py", line 20, in default
return o.as_dict()
File "/srv/homeassistant/lib/python3.9/site-packages/homeassistant/core.py", line 1126, in as_dict
if not self._as_dict:
AttributeError: _as_dict
It does not occur if I shut HA down imediatly after starting it, it looks like it is only after some hours of activity.
I use Home Assistant Core now updated to 2022.6.6 on an Odroid N2+ under Raspbian Bullseye 22.05.
Last time I observed this error was when I updated Home Assistant 2022.6.5 to 2022.6.6.
Do I have an error on a JSON file in .storage? Using JQ all looks good and HA starts correctly, I suppose Home Assistant could not start if I had an mal-formed json file.
What could cause this kind of error?
