I found out this error in the HA logs.
I cannot figure out what is wrong because I cannot remember to have see it before.
I am using HA running in a docker-container from the image homeassistant/raspberrypi3-homeassistant:latest
I installed HACS and Alexa Media Player as integrations but they looks to run fine.
I can understand that the error in connected to notify component but nothing else.
What could be wrong?
Apparently HA works fine without any problem.
Thank You
Regards
M.
2019-09-22 12:25:24 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/components/notify/__init__.py", line 96, in async_setup_platform
notify_service.hass = hass
AttributeError: 'bool' object has no attribute 'hass'
