can anyone help why this script is aborting with:
16-11-02 01:28:32 homeassistant.bootstrap: Error during setup of component thermostat
File "/srv/hass/lib/python3.4/site-packages/homeassistant/bootstrap.py", line 102, in _setup_component
result = component.setup(hass, config)
AttributeError: 'module' object has no attribute 'setup'
Script: (CONFIG_DIR/custom_components/thermostat/max.py
import logging
from homeassistant.components.thermostat import ThermostatDevice
from homeassistant.const import TEMP_CELCIUS
from homeassistant.helpers.temperature import convert
from maxcube.connection import *
from maxcube.cube import *
from maxcube.device import *
from maxcube.thermostat import *
REQUIREMENTS = ['python-maxcube-api']
CONF_IP = 'ip'
CONF_PORT = 'port'
PROPERTY_SET_TEMPERATURE = 'SET_TEMPERATURE'
PROPERTY_ACTUAL_TEMPERATURE = 'ACTUAL_TEMPERATURE'
PROPERTY_MODE = 'MODE'
_LOGGER = logging.getLogger(__name__)
def setup_platform(hass, config, add_devices, discovery_info=None):
"""Setup the Max!Cube thermostat."""
devices = []
try:
cubeConn = MaxCubeConnection(config[CONF_IP], config[CONF_PORT])
cube = MaxCube(cubeConn)
for device in cube.get_devices():
devices.append(MaxThermostat(cube, device.rf_address))
except socket.error:
_LOGGER.exception("Connection error to Max!Cube")
return False
add_devices(devices)
return True
# pylint: disable=too-many-instance-attributes
class MaxThermostat(ThermostatDevice):
"""Representation of a Homematic thermostat."""
def __init__(self, cube, _id):
"""Initialize the thermostat."""
self.cube = cube
self._id = _id
self._device = cube.device_by_rf(_id)
@property
def should_poll(self):
"""Polling needed for thermostat."""
return True
@property
def name(self):
"""Return the name of the Homematic device."""
return self._device.name
@property
def unit_of_measurement(self):
"""Return the unit of measurement that is used."""
return TEMP_CELSIUS
@property
def current_temperature(self):
"""Return the current temperature."""
return self._device.actual_temperature
@property
def target_temperature(self):
"""Return the temperature we try to reach."""
return self._device.target_temperature
def set_temperature(self, temperature):
"""Set new target temperature."""
self.cube.set_target_temperature(self._device, temperature)
@property
def device_state_attributes(self):
"""Return the device specific state attributes."""
return {"mode": self._device.mode}
@property
def min_temp(self):
"""Return the minimum temperature."""
return round(convert(4.5, TEMP_CELSIUS, self.unit_of_measurement))
@property
def max_temp(self):
"""Return the maximum temperature."""
return round(convert(30.5, TEMP_CELSIUS, self.unit_of_measurement))
def update(self):
"""Update the data from the thermostat."""
try:
self.cube.update()
_LOGGER.exception("Did not receive any temperature data from the "
"Max!Cube API.")
