I’m running Home Assistant (version 2021.1.1) on Clear Linux. After one of the latest updates, I’m no longer able to login to the web interface. The follow error shows in the log for every login attempt:
2021-01-13 18:39:23 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/lib/python3.9/site-packages/aiohttp/web_protocol.py", line 422, in _handle_request
resp = await self._request_handler(request)
File "/usr/lib/python3.9/site-packages/aiohttp/web_app.py", line 499, in _handle
resp = await handler(request)
File "/usr/lib/python3.9/site-packages/aiohttp/web_middlewares.py", line 118, in impl
return await handler(request)
File "/usr/lib/python3.9/site-packages/homeassistant/components/http/request_context.py", line 18, in request_context_middleware
File "/usr/lib/python3.9/site-packages/homeassistant/components/http/ban.py", line 72, in ban_middleware
File "/usr/lib/python3.9/site-packages/homeassistant/components/http/auth.py", line 127, in auth_middleware
File "/usr/lib/python3.9/site-packages/homeassistant/components/http/view.py", line 129, in handle
result = await result
File "/usr/lib/python3.9/site-packages/homeassistant/components/http/ban.py", line 83, in handle_req
resp = await func(view, request, *args, **kwargs)
File "/usr/lib/python3.9/site-packages/homeassistant/components/auth/__init__.py", line 251, in post
return await self._async_handle_auth_code(hass, data, request.remote)
File "/usr/lib/python3.9/site-packages/homeassistant/components/auth/__init__.py", line 314, in _async_handle_auth_code
access_token = hass.auth.async_create_access_token(refresh_token, remote_addr)
File "/usr/lib/python3.9/site-packages/homeassistant/auth/__init__.py", line 446, in async_create_access_token
return jwt.encode(
AttributeError: 'str' object has no attribute 'decode'
I have posted the issue on github:
