I want to create a macro that will test on my Ical sensor calendar events if a certain date is a work day, and if so, at what time do I start working.
It’s not a problem having a code working to find 1. the boolean value if a mentioned date is a workday and 2. for the start hour in case it’s a workday.
What I would like to have is to get the hour as a variable attribute, but from my testing it doesn’t seem to work.
What I’m looking for would be similar to what we see in the demo template with the ‘my_test_json’ variable:
{{ is_it_workday('2023-06-01') }}
would return a boolean value and
{{ is_it_workday('2023-06-01').time }}
would have the start time of my work.
Is there any way to realize this, or get a similar practical result in a way not too unelegant?
(Of course I know there are solutions like returning the hour if workday and nothing if else. But I want the actual answer to my question since there are different cases where I would want mulitple values from a macro.)
Thanks a lot! I was just about to publish the version I succeeded to realize, when I saw your last response.
Here is how my actual code look like, more or less:
For my macro:
(some code here determining the values if it is a workday and if so at what time)
{%- set is_workday_hour = {'isworkday': booleanvar_wday, 'hour': hour_var}|to_json -%}
{{ is_workday_hour }}
{%- endmacro %}
Any template using the macro would start like this:
{% from 'tools.jinja' import is_workday %}
{% set wd = is_workday('2023-04-29')|from_json %}
Then I can follow with this:
wd.isworkday (would return true or false)
wd.hour (would return the time or None)
without having to call a second or third time the whole processing of the macro.
So it does need some extra lines, but not so many and this is a good enough solution for me.
Thanks again for pointing me in the right direction.
