Attributes from Camera connected via Frigate missing after IP change
Hello community,
I have a behaviour which I cannot explain.
I have Home Assistant with Frigate integration and some cameras connected to Frigate. Since my router crashed I changed to a new one and also changed the IPs of all devices (Frigate from 192.168.0.212 to 192.168.2.3). Now I can see the video stream of the camera but all the rest of the attributes are unavailable for all cameras like car count, motion, person count etc.
When I go from my PC to http://frigate/api/stats I see:
|balcony||
|audio_dBFS|0|
|audio_rms|0|
|camera_fps|5|
|capture_pid|337|
|detection_enabled|1|
|detection_fps|1.8|
|ffmpeg_pid|349|
|pid|331|
|process_fps|5|
|skipped_fps|0|
Does anybody has any idea what is causing the problem? I have no idea how to fix that.
Best
Tbs
Solved, the IP adress of the MQTT broker must be changed manually.
