Atvremote is returning a Command not Found
I have installed HASSIO over Raspbian and also tried the stand alone HASSIO setup.
Either way I do not get the option to select the apple_tv service. Even when I run the setup throught he ssh commands everything installs without an error however I get the following error when I run the ‘atvremote scan’ command. “-bash: atvremote: command not found”
Try adding apple_tv: to your config and the services should appear.
Thank you for that advice, it added the service. The problem I have now is that the service doesn’t return a result. When I run ‘atvremote scan’ I get “-bash: atvremote: command not found”.
I suspect something is not installing correctly. I have followed this guide, https://www.home-assistant.io/components/apple_tv/,
Perhaps there is a better guide?
thanks again.
EDIT - i found this “AppleTV error in 0.49” where it points out to use ‘sudo pip3 install --upgrade pyatv’ and this fixed the issue.
