Atvremote - scan error
Trying to add my Apple Tv gen4 to HA. install ATVremote. but when i run scan i get the following error.
what is causing this
  File "/usr/local/bin/atvremote", line 7, in <module>
    from pyatv.__main__ import main
  File "/usr/local/lib/python3.4/dist-packages/pyatv/__init__.py", line 13, in <module>
    from pyatv.internal.apple_tv import AppleTVInternal
  File "/usr/local/lib/python3.4/dist-packages/pyatv/internal/apple_tv.py", line 19, in <module>
    from pyatv.airplay.srp import (SRPAuthHandler, new_credentials)
  File "/usr/local/lib/python3.4/dist-packages/pyatv/airplay/srp.py", line 8, in <module>
    import curve25519
thanks
Looks like all dependencies not have been installed correctly. How did you install and run it?
