Hello!
Are there any plans to add support for an audio on Lovelace UI from RTSP camera stream?
most video processing apps that I know of, (zoneminder, motion, motioneye) do not support audio. I suspect the same will remain with HA…
If you add stream: to your configuration and click on a picture glance set to camera, you do get the option to mute/unmute speakers. Doesn’t seem to do anything though.
That was going to be my point: lolouk44 thought it unlikely, but I have seen the option to mute the stream. As of today, I can’t get audio from my RTSP stream, but if i play the stream from VLC, I get audio.
Projects like this make it easy to get audio and even 2-way with supported cameras.
https://community.home-assistant.io/t/go2rtc-project-help-thread/
