I’m using the companion app on a macbook pro, and it’s pretty fantastic. However, I’m trying to use the audio_input_in_use
sensor, as I assumed that it would change state when I join a huddle in slack, for example. I can see the bluetooth headphones listed in the sensor attribute, but the state is always “off”
Did I misunderstand the sensor, or is something wrong with the way I’ve set things up? The camera_in_use
sensor works great as a trigger for the same automation, but I’d like it to run when I’m using the audio input as well.
Any help is appreciated!
