Audio (microphone) Support for a Video Doorbell Integration
yes, its installed :slight_smile:
double check the installed package name and also check the default webview being used…then check app configuration logs to see what package we are printing.
ok, now i’m lost :slight_smile:
how do i do that ? :slight_smile:
  1. To check package name you go to App info for webview and read the package name
  2. You have a custom ROM its your responsibility to know how to change things, I dont use a custom ROM but I know for a fact lineage uses unsupported webview packages because I had helped others in the past and they figured out where the change is. Try looking in developer tools?
  3. You know where to check the logs as you already provided them.
ok,
if i test the SIP , in a browser instead ofn companion app, if it works then, is it then still related to the webview? so if you say that webview is causing it, then it should not work on chrome browser on android app, right? i can do that test later
your browser does not use the webview package :wink:
no they are not the same thing.
ah ok , thnx , gonna test later
i think its the rigtht app, cant see the package name thouh, see screens::
scroll down in the second screenshot, it should be there…did you look at the logs? we also print the used package name there too
hmm, cant scroll down in that second screenshot, there is just one more line, wirh the version nr
but i already supplies the log file? :slight_smile:
i’m quite sure the correct webview is installed , gonna look for package name later , maybe i can see it with other app
no it was missing…force stop the app…reopen the app and go to the logs and you should see a line like: android/app/src/main/java/io/homeassistant/companion/android/webview/WebViewActivity.kt at 74f8d8453cadacf8cd2a328dbac4fb6ec4e411f3 · home-assistant/android · GitHub
ahh, ok, clear :slight_smile:
here it is :
12-20 16:18:11.236 31654 31654 D WebviewActivity: Current webview package com.google.android.webview and version 96.0.4664.104
here is more from the log, where it failed:
--------- beginning of main
12-20 16:18:10.566 31654 31654 E mpanion.androi: Not starting debugger since process cannot load the jdwp agent.
12-20 16:18:10.599 31654 31654 W mpanion.androi: JIT profile information will not be recorded: profile file does not exits.
12-20 16:18:10.599 31654 31654 I chatty  : uid=10243(io.homeassistant.companion.android) identical 2 lines
12-20 16:18:10.603 31654 31654 I Perf    : Connecting to perf service.
12-20 16:18:10.604 31654 31654 I mpanion.androi: [GL_OOM] ClampGrowthLimit 268435456
12-20 16:18:10.618 31654 31654 I FirebaseApp: Device unlocked: initializing all Firebase APIs for app [DEFAULT]
12-20 16:18:10.630 31654 31654 I FirebaseInitProvider: FirebaseApp initialization successful
12-20 16:18:10.634 31654 31654 D WM-WrkMgrInitializer: Initializing WorkManager with default configuration.
12-20 16:18:10.636 31654 31680 I DynamiteModule: Considering local module com.google.android.gms.measurement.dynamite:55 and remote module com.google.android.gms.measurement.dynamite:59
12-20 16:18:10.637 31654 31680 I DynamiteModule: Selected remote version of com.google.android.gms.measurement.dynamite, version >= 59
12-20 16:18:10.637 31654 31680 V DynamiteModule: Dynamite loader version >= 2, using loadModule2NoCrashUtils
12-20 16:18:10.650 31654 31654 D Sentry  : io.sentry.auto-init read: false
12-20 16:18:10.650 31654 31654 I Sentry  : Retrieving auto-init from AndroidManifest.xml
12-20 16:18:10.654 31654 31654 V Font    : Change font:1
12-20 16:18:10.654 31654 31654 V Font    : Default family:android.graphics.Typeface@adee4916
12-20 16:18:10.659 31654 31680 W mpanion.androi: ClassLoaderContext type mismatch. expected=PCL, found=DLC (PCL[] | DLC[];PCL[/data/app/io.homeassistant.companion.android--ZyYOWsyu9FM19wVeq-YBA==/base.apk*3880022450:/data/app/io.homeassistant.companion.android--ZyYOWsyu9FM19wVeq-YBA==/base.apk!classes2.dex*2193253564:/data/app/io.homeassistant.companion.android--ZyYOWsyu9FM19wVeq-YBA==/base.apk!classes3.dex*2657825457:/data/app/io.homeassistant.companion.android--ZyYOWsyu9FM19wVeq-YBA==/base.apk!classes4.dex*4184013010])
12-20 16:18:10.659 31654 31680 W mpanion.androi: Found duplicate classes, falling back to extracting from APK : /data/user_de/0/com.google.android.gms/app_chimera/m/000000a2/MeasurementDynamite.apk
12-20 16:18:10.660 31654 31680 W mpanion.androi: NOTE: This wastes RAM and hurts startup performance.
12-20 16:18:10.660 31654 31680 W mpanion.androi: Found duplicated class when checking oat files: 'Landroid/support/v4/app/RemoteActionCompatParcelizer;' in /data/user_de/0/com.google.android.gms/app_chimera/m/000000a2/MeasurementDynamite.apk and /data/app/io.homeassistant.companion.android--ZyYOWsyu9FM19wVeq-YBA==/base.apk
12-20 16:18:10.663 31654 31680 I mpanion.androi: Waiting for a blocking GC ClassLinker
12-20 16:18:10.689 31654 31654 W pool-12-thread-: type=1400 audit(0.0:37776): avc: denied { read } for name="version" dev="proc" ino=4026532095 scontext=u:r:untrusted_app:s0:c243,c256,c512,c768 tcontext=u:object_r:proc_version:s0 tclass=file permissive=0
12-20 16:18:10.695 31654 31709 D Sentry  : SU isn't found on this Device.
12-20 16:18:10.725 31654 31707 E Perf    : Fail to get file list io.homeassistant.companion.android
12-20 16:18:10.726 31654 31707 E Perf    : getFolderSize() : Exception_1 = java.lang.NullPointerException: Attempt to get length of null array
12-20 16:18:10.727 31654 31707 E Perf    : Fail to get file list oat
12-20 16:18:10.727 31654 31707 E Perf    : getFolderSize() : Exception_1 = java.lang.NullPointerException: Attempt to get length of null array
12-20 16:18:10.741 31654 31654 I WebViewFactory: Loading com.google.android.webview version 96.0.4664.104 (code 466410434)
12-20 16:18:10.746 31654 31716 I FA      : App measurement initialized, version: 50018
12-20 16:18:10.746 31654 31716 I FA      : To enable debug logging run: adb shell setprop log.tag.FA VERBOSE
12-20 16:18:10.746 31654 31716 I FA      : To enable faster debug mode event logging run:
12-20 16:18:10.746 31654 31716 I FA      :   adb shell setprop debug.firebase.analytics.app io.homeassistant.companion.android
12-20 16:18:10.765 31654 31654 I cr_WVCFactoryProvider: Loaded version=96.0.4664.104 minSdkVersion=29 isBundle=true multiprocess=true packageId=2
12-20 16:18:10.773 31654 31654 I cr_LibraryLoader: Successfully loaded native library
12-20 16:18:10.773 31654 31654 I cr_CachingUmaRecorder: Flushed 7 samples from 7 histograms.
12-20 16:18:10.775 31654 31654 D NetworkSecurityConfig: Using Network Security Config from resource network_security_config debugBuild: false
12-20 16:18:10.804 31654 31716 I FA      : Tag Manager is not found and thus will not be used
12-20 16:18:10.806 31654 31654 V ViewRootImpl: The specified message queue synchronization  barrier token has not been posted or has already been removed
12-20 16:18:10.837 31654 31654 W mpanion.androi: Accessing hidden method Landroid/content/res/Resources$Theme;->getKey()Landroid/content/res/Resources$ThemeKey; (greylist-max-o, reflection, denied)
12-20 16:18:10.863 31654 31671 D DecorView: onWindowFocusChangedFromViewRoot hasFocus: true, DecorView@fbf383c[LaunchActivity]
12-20 16:18:10.863 31654 31708 I AdrenoGLES: QUALCOMM build                   : 35556ba, I9ca166462c
12-20 16:18:10.863 31654 31708 I AdrenoGLES: Build Date                       : 08/07/19
12-20 16:18:10.863 31654 31708 I AdrenoGLES: OpenGL ES Shader Compiler Version: EV031.27.02.00
12-20 16:18:10.863 31654 31708 I AdrenoGLES: Local Branch                     :
12-20 16:18:10.863 31654 31708 I AdrenoGLES: Remote Branch                    :
12-20 16:18:10.863 31654 31708 I AdrenoGLES: Reconstruct Branch               :
12-20 16:18:10.863 31654 31708 I AdrenoGLES: Build Config                     : S P 8.0.8 AArch64
12-20 16:18:10.865 31654 31708 I AdrenoGLES: PFP: 0x016ee187, ME: 0x00000000
12-20 16:18:10.879 31654 31708 W Gralloc3: mapper 3.x is not supported
12-20 16:18:10.886 31654 31708 D         : Successfully load libgui-plugin.so, this=0x7c02832050
12-20 16:18:10.886 31654 31654 W Choreographer: Already have a pending vsync event.  There should only be one at a time.
12-20 16:18:10.894 31654 31654 D SensorReceiver: Sensor audio_sensor corresponding to received event android.media.RINGER_MODE_CHANGED is disabled, skipping sensors update
12-20 16:18:10.897 31654 31654 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 16:18:10.897 31654 31654 D UrlRepository: Using external URL
12-20 16:18:10.899 31654 31654 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 16:18:10.906 31654 31700 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 16:18:10.912 31654 31735 I DpmTcmClient: RegisterTcmMonitor from: $Proxy0
12-20 16:18:10.937 31654 31654 W ActivityThread: handleWindowVisibility: no activity for token android.os.BinderProxy@a885e30
12-20 16:18:11.126 31654 31699 D LocBroadcastReceiver: Registering for zone based location updates
12-20 16:18:11.137 31654 31699 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 16:18:11.196 31654 31698 D SensorReceiver: Nothing to update
12-20 16:18:11.197 31654 31654 D PhoneWindow: setNavigationBarColor: ff111111
12-20 16:18:11.200 31654 31654 D RenderScript HIDL Adaptation: IRenderScriptDevice::getService()
12-20 16:18:11.205 31654 31654 D RenderScript HIDL Adaptation: IRenderScriptDevice::getService() returned 0x7af7e80160
12-20 16:18:11.205 31654 31654 D RenderScript HIDL Adaptation: HIDL successfully loaded.
12-20 16:18:11.219 31654 31820 V RenderScript: Successfully loaded runtime: libRSDriver_adreno.so
12-20 16:18:11.220 31654 31654 D         : Successfully queried cache dir: /data/user_de/0/io.homeassistant.companion.android/code_cache
12-20 16:18:11.220 31654 31654 D RenderScript: Setting cache dir: /data/user_de/0/io.homeassistant.companion.android/code_cache
12-20 16:18:11.235 31654 31654 I System.out: recordForce value 5
12-20 16:18:11.269 31654 31654 V ViewRootImpl: The specified message queue synchronization  barrier token has not been posted or has already been removed
12-20 16:18:11.285 31654 31671 D DecorView: onWindowFocusChangedFromViewRoot hasFocus: true, DecorView@b72524d[WebViewActivity]
12-20 16:18:11.308 31654 31654 W Choreographer: Already have a pending vsync event.  There should only be one at a time.
12-20 16:18:11.328 31654 31654 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 16:18:11.328 31654 31654 D UrlRepository: Using external URL
12-20 16:18:11.329 31654 31699 D SensorWorker: Updating all Sensors.
12-20 16:18:11.332 31654 31834 I WM-Processor: Moving WorkSpec (b28623c5-02cb-4e3a-b1fb-4513eb78b217) to the foreground
12-20 16:18:11.395 31654 31654 I WM-SystemFgDispatcher: Started foreground service Intent { act=ACTION_START_FOREGROUND cmp=io.homeassistant.companion.android/androidx.work.impl.foreground.SystemForegroundService (has extras) }
12-20 16:18:11.473 31654 31698 D LocBroadcastReceiver: Registering for location updates.
12-20 16:18:11.516 31654 31654 D LocBroadcastReceiver: Received location update.
12-20 16:18:11.527 31654 31654 D LocBroadcastReceiver: Received location update.
12-20 16:18:11.532 31654 31654 D ForegrndServiceLauncher: Check if service HighAccuracyLocationService is running. Service running = false
12-20 16:18:11.532 31654 31654 D LocBroadcastReceiver: Last Location:
12-20 16:18:11.532 31654 31654 D LocBroadcastReceiver: Coords:(50.9964134, 5.2475992)
12-20 16:18:11.532 31654 31654 D LocBroadcastReceiver: Accuracy: 13.724
12-20 16:18:11.532 31654 31654 D LocBroadcastReceiver: Bearing: 0.0
12-20 16:18:11.532 31654 31654 D LocBroadcastReceiver: Begin evaluating if location update should be skipped
12-20 16:18:11.532 31654 31654 D LocBroadcastReceiver: Received location that is 31 milliseconds old, 1640013491501 compared to 1640013491532 with source fused
12-20 16:18:11.533 31654 31698 D UrlRepository: localUrl is: false and usesInternalSsid is: false
12-20 16:18:11.571 31654 31699 D SensorReceiver: Nothing to update
12-20 16:18:11.576 31654 31701 I WM-WorkerWrapper: Worker result SUCCESS for Work [ id=b28623c5-02cb-4e3a-b1fb-4513eb78b217, tags={ io.homeassistant.companion.android.sensors.SensorWorker } ]
12-20 16:18:11.579 31654 31654 I WM-SystemFgDispatcher: Stopping foreground service
12-20 16:18:12.135 31654 31870 D WebviewActivity: External bus {"type":"connection-status","payload":{"event":"connected"},"id":1}
12-20 16:18:12.146 31654 31698 D LocBroadcastReceiver: Location update sent successfully
12-20 16:18:12.514 31654 31870 D WebviewActivity: External bus {"type":"theme-update","id":2}
12-20 16:18:12.569 31654 31654 D WebviewActivity: Color from webview is "rgb(23, 23, 23)-SPACER-rgb(23, 23, 23)"
12-20 16:18:12.569 31654 31698 D WebViewPresenterImpl: Try getting color from webview color "rgb(23, 23, 23)".
12-20 16:18:12.569 31654 31698 I WebViewPresenterImpl: Found color -15263977.
12-20 16:18:12.570 31654 31698 D WebViewPresenterImpl: Try getting color from webview color "rgb(23, 23, 23)".
12-20 16:18:12.570 31654 31698 I WebViewPresenterImpl: Found color -15263977.
12-20 16:18:12.571 31654 31654 D PhoneWindow: setNavigationBarColor: ff171717
12-20 16:18:12.612 31654 31870 D WebviewActivity: External bus {"type":"config/get","id":3}
12-20 16:18:12.614 31654 31654 D WebviewActivity: externalBus({"id":3,"type":"result","success":true,"result":{"hasSettingsScreen":true,"canWriteTag":true,"hasExoPlayer":true}});
12-20 16:18:12.654 31654 31654 D WebviewActivity: Callback null
12-20 16:18:12.655 31654 31654 D WebviewActivity: Color from webview is "rgb(23, 23, 23)-SPACER-rgb(23, 23, 23)"
12-20 16:18:12.655 31654 31699 D WebViewPresenterImpl: Try getting color from webview color "rgb(23, 23, 23)".
12-20 16:18:12.655 31654 31699 I WebViewPresenterImpl: Found color -15263977.
12-20 16:18:12.661 31654 31698 D WebViewPresenterImpl: Try getting color from webview color "rgb(23, 23, 23)".
12-20 16:18:12.662 31654 31698 I WebViewPresenterImpl: Found color -15263977.
12-20 16:18:12.662 31654 31654 D PhoneWindow: setNavigationBarColor: ff171717
12-20 16:18:14.398 31654 31870 D WebviewActivity: External bus {"type":"haptic","payload":{"hapticType":"light"},"id":4}
12-20 16:18:14.399 31654 31654 D WebviewActivity: Processing haptic tag for light
12-20 16:18:14.734 31654 31654 E SensorManager: registerListenerImpl sensorName:Game Rotation Vector  Wakeup,isWakeUpSensor:true,callingApp: io.homeassistant.companion.android,callingPid:31654,callingUid:10243
12-20 16:18:14.925 31654 31654 E SensorManager: unregisterListenerImpl sensorName:Game Rotation Vector  Wakeup,isWakeUpSensor:true,callingApp: io.homeassistant.companion.android,callingPid:31654,callingUid:10243
12-20 16:18:24.317 31654 31844 W VideoCapabilities: Unsupported mime image/vnd.android.heic
12-20 16:18:24.319 31654 31844 W VideoCapabilities: Unsupported mime video/divx
12-20 16:18:24.319 31654 31844 W VideoCapabilities: Unsupported mime video/divx4
12-20 16:18:24.321 31654 31844 W VideoCapabilities: Unrecognized profile/level 0/3 for video/mpeg2
12-20 16:18:24.322 31654 31844 W VideoCapabilities: Unsupported mime video/x-ms-wmv
12-20 16:18:24.387 31654 31774 I AudioManager: In isBluetoothScoOn(), calling application: io.homeassistant.companion.android
12-20 16:18:24.387 31654 31774 I AudioManager: In startbluetoothSco(), calling application: io.homeassistant.companion.android
12-20 16:18:24.396 31654 31774 I AudioManager: In isSpeakerphoneOn(), calling application: io.homeassistant.companion.android
12-20 16:18:24.400 31654 31774 I AudioManager: In setMode(), mode: 3, calling application: io.homeassistant.companion.android
12-20 16:18:24.447 31654 31774 I libOpenSLES: Emulating old channel mask behavior (ignoring positional mask 0x1, using default mask 0x10 based on channel count of 1)
12-20 16:18:24.461 31654 31774 I AudioRecord: createRecord_l(6553714): AUDIO_INPUT_FLAG_FAST successful; frameCount 0 -> 4096
12-20 16:18:24.464 31654 31654 E chromium: [ERROR:web_contents_delegate.cc(228)] WebContentsDelegate::CheckMediaAccessPermission: Not supported.
12-20 16:18:24.586 31654 31774 I AudioManager: In isBluetoothScoOn(), calling application: io.homeassistant.companion.android
12-20 16:18:24.586 31654 31774 E cr_media: Unable to stop BT SCO since it is already disabled
12-20 16:18:24.587 31654 31774 I AudioManager: In isSpeakerphoneOn(), calling application: io.homeassistant.companion.android
12-20 16:18:24.587 31654 31774 I AudioManager: In setMode(), mode: 0, calling application: io.homeassistant.companion.android
12-20 16:18:33.620 31654 31870 D WebviewActivity: External bus {"type":"config_screen/show","id":5}
12-20 16:18:33.640 31654 31654 W ActivityThread: handleWindowVisibility: no activity for token android.os.BinderProxy@d199e76
12-20 16:18:33.664 31654 31654 D UrlRepository: Using external URL
12-20 16:18:33.665 31654 31654 I chatty  : uid=10243(io.homeassistant.companion.android) identical 2 lines
12-20 16:18:33.665 31654 31654 D UrlRepository: Using external URL
12-20 16:18:33.677 31654 31654 V FlingOptimizerScroller: FlingOptimizerOverScroller Init
12-20 16:18:33.683 31654 31654 V ViewRootImpl: The specified message queue synchronization  barrier token has not been posted or has already been removed
12-20 16:18:33.691 31654 31873 D DecorView: onWindowFocusChangedFromViewRoot hasFocus: true, DecorView@c4db136[SettingsActivity]
12-20 16:18:33.744 31654 31654 W Choreographer: Already have a pending vsync event.  There should only be one at a time.
12-20 16:18:33.796 31654 31699 D SensorWorker: Updating all Sensors.
12-20 16:18:33.798 31654 31834 I WM-Processor: Moving WorkSpec (24901bd0-da1d-45d9-bbbe-7cf665533faf) to the foreground
12-20 16:18:33.808 31654 31654 I WM-SystemFgDispatcher: Started foreground service Intent { act=ACTION_START_FOREGROUND cmp=io.homeassistant.companion.android/androidx.work.impl.foreground.SystemForegroundService (has extras) }
12-20 16:18:33.926 31654 31698 D SensorReceiver: Nothing to update
12-20 16:18:33.927 31654 31837 I WM-WorkerWrapper: Worker result SUCCESS for Work [ id=24901bd0-da1d-45d9-bbbe-7cf665533faf, tags={ io.homeassistant.companion.android.sensors.SensorWorker } ]
12-20 16:18:33.930 31654 31654 I WM-SystemFgDispatcher: Stopping foreground service
12-20 16:18:39.257 31654 31654 I Surface : opservice is null false
12-20 16:18:40.856 31654 31699 D LogcatReader: Read logcat for pid 31654
12-20 16:18:40.940 31654 31699 D LogcatReader: Done reading logcat for pid 31654
12-20 16:18:43.364 31654 31654 V ViewRootImpl: The specified message queue synchronization  barrier token has not been posted or has already been removed
12-20 16:18:43.381 31654 31873 D DecorView: onWindowFocusChangedFromViewRoot hasFocus: true, DecorView@80f3476[SettingsActivity]
12-20 16:18:43.421 31654 31654 W Choreographer: Already have a pending vsync event.  There should only be one at a time.
12-20 16:18:44.973 31654 31654 I Surface : opservice is null false
12-20 16:18:46.327 31654 31654 D LogFragment: User want to share log
12-20 16:18:46.338 31654 31654 I LogFragment: Create log file to: /storage/emulated/0/Android/data/io.homeassistant.companion.android/cache/logs/homeassistant_companion_log_11-20-2021_16-18-46.txt
12-20 16:18:46.346 31654 31654 I LogFragment: Open share dialog with log file
12-20 16:18:46.361 31654 31708 D OpenGLRenderer: endAllActiveAnimators on 0x7afb925600 (RippleDrawable) with handle 0x7aad1ebb60
12-20 16:18:46.364 31654 31675 D DecorView: onWindowFocusChangedFromViewRoot hasFocus: true, DecorView@c4db136[SettingsActivity]
12-20 16:18:46.559 31654 31675 E ContentProviderNative: onTransact error from {P:32015;U:1000}
12-20 16:18:46.559 31654 31675 E DatabaseUtils: Writing exception to parcel
12-20 16:18:46.559 31654 31675 E DatabaseUtils: java.lang.SecurityException: Permission Denial: reading androidx.core.content.FileProvider uri content://io.homeassistant.companion.android.provider/external_files/Android/data/io.homeassistant.companion.android/cache/logs/homeassistant_companion_log_11-20-2021_16-18-46.txt from pid=32015, uid=1000 requires the provider be exported, or grantUriPermission()
12-20 16:18:46.559 31654 31675 E DatabaseUtils: 	at android.content.ContentProvider.enforceReadPermissionInner(ContentProvider.java:781)
12-20 16:18:46.559 31654 31675 E DatabaseUtils: 	at android.content.ContentProvider$Transport.enforceReadPermission(ContentProvider.java:645)
12-20 16:18:46.559 31654 31675 E DatabaseUtils: 	at android.content.ContentProvider$Transport.query(ContentProvider.java:239)
12-20 16:18:46.559 31654 31675 E DatabaseUtils: 	at android.content.ContentProviderNative.onTransact(ContentProviderNative.java:114)
12-20 16:18:46.559 31654 31675 E DatabaseUtils: 	at android.os.Binder.execTransactInternal(Binder.java:1032)
12-20 16:18:46.559 31654 31675 E DatabaseUtils: 	at android.os.Binder.execTransact(Binder.java:1005)
12-20 16:18:59.520 31654 32232 D DecorView: onWindowFocusChangedFromViewRoot hasFocus: true, DecorView@c4db136[SettingsActivity]
12-20 16:19:11.405 31654 31654 I Surface : opservice is null false
its possible that exoplayer and/or webview does not suppport the mime type. The app doesnt provide any restrictions there
ow ok , so nothing we can do about it then?
i dont think so but you are more than welcome to open an issue on github with the corresponding logs so others know
Ok , I will do that, thnx for all info
Just trying to understand the app, why are the streams coming from the camera integration showing without an issue? Is there somekind of converting
more of a frontend question than the app, we just display what the frontend tells us to
ok, anyway, issue created:
