ive succefully configure icecast/mopidy/chromecast devices to play audio. however my switch to turn the audio stream on/off toggles back to off automatically, the audio starts playing. However if toggling it again it doesnt stop the audio. I think in theory the switch should remain on while audio is playing and turn it off will stop the audio.
I have done a template switch to control this config below.
Any thoughts or input on this would be gratefully recieved…
you also have to setup Icecast of cause. - This helped me - Also you can setup to play a silent file fhile skipping to the next track that the CCA dont loose connection
<hostname>127.0.0.1</hostname>
<!-- You may have multiple <listener> elements -->
<listen-socket>
<port>8000</port>
<!-- <bind-address>127.0.0.1</bind-address> -->
<!-- <shoutcast-mount>/stream</shoutcast-mount> -->
</listen-socket>
<mount>
<mount-name>/mopidy.mp3</mount-name>
<fallback-mount>/1sec.mp3</fallback-mount>
<fallback-override>1</fallback-override>
</mount>
Hey @Underknowledge Could you possibly expand a bit more on this bit for me. I have icecast/mopidy all setup and working for the last year or so now, but has always annoyed me that it doesn’t continue streaming when you hit next track on MPD.
I have this added into my config, but still have the same problem with it stopping after trying to change tracks. The file is there in the path. Sure I am missing something easy, but any help is super appreciated.
I stumbled across it in the mopidy forum - Sadly I dont find the post atm.
here the config and the mp3 I use icecast.xml (9.1 KB) 1sec.mp3.renametomp3.xml (19.9 KB) mopidy.conf.yaml (3.2 KB)
and the docks on mopidy https://docs.mopidy.com/en/latest/audio/#fallback-stream file needs to be placed in the directory defined by <webroot>...</webroot> in the Icecast configuration.
so my guess is icecast try to load /etc/icecast2//etc/icecast2/1sec.mp3 on your side
