šŸ“¢ August 13th - Save the date!
I’ve already got the TubesZB Z-Wave controller (POE), but not implemented yet.
What I REALLY want, is for HA to allow multiple Z-Wave controllers/networks.
I’m at the point where I’m seriously thinking to go with linked multiple HA instances.
Main use case is two radio-isolated buildings that already have Ethernet connectivity. (One building is basically a Faraday cage.) How do I connect Z-Wave devices in that building? I’ve already handled Zigbee, using Zigbee2MQTT with a UZG-01 gateway.
When using multiple instances you can use this integration to have the devices populate in the primary instance for monitoring:
The other option is if the co-orinator has a vpn option in its settings you can then link it back this way to the same internal network.
You can add multiple Z-wave integrations already, and there are simple hacks to add multiple Z-wave-JS UI Add-ons by simply adding a ā€œ/ā€ to the second instance. Check the forum here for details. Someone recently posted about adding 3 Add-on instances this way.
Plenty of people are running multiple Z-wave networks with Home Assistant.
I would love to see a Z-Wave stick/device. I must say that I really like the SM Light POE Zigbee stick POE version, so POE would have my preference, put it anywhere where I like it. USB is very limited.
Wonderful; thanks for that. I’ll check it out.
That should be doable if you use Z-Wave JS, as you can run multiple instances of it (for example, by using multiple Docker containers)
Hopefully it supports Ethernet, ideally PoE. There’s plenty of USB dongles already available, but Ethernet is much more flexible as you can put it anywhere reachable via Ethernet cable, instead of being limited to just being plugged in to your server.
my only wish would be it has a stronger antenna and consequently a better mesh
faulty readings have come so abundant lately, (and are utterly proposterous, a daily energy use of thousands/millions kWh’s…)
that I cant really rely on the z-wave sensors anymore, and use the energy panel only anecdotally…
and it’s messy because those faulty readings trickle down into the utility sensors…
so, I’d very much welcome a modern device that wouldn’t be troubled by this
Good timing
I was about to buy another vendor’s new Z-Wave radio, so if the NABU compares well, I may consider it instead.
It must have at minimum: 1. Ethernet connectivity with PoE and 2. External antenna
Releasing anything without Ethernet and PoE is IMO, a waste of time. It would be a big money loser.
It’s for sale, but you buy it knowing that it’s not yet certified. So that makes you a ā€œtesterā€ - you can get it on AliExpress right now (when it’s not out of stock)
With one or more ethernet-connected Z-Wave controllers. You can simply wire back to your LAN OR with your own VPN/tunnel, you can even place this controller anywhere else on the planet connected to the internt and treat it as if it’s local. This is easy with the SM Light products, but I can’t speak for any others.
Technically true, but practically false due to latency. It wouldn’t work well.
But I agree with your points on the benefits of Ethernet connected adapters vs USB.
Instead of a Ethernet-bridge I use a a pair of dumb ā€œUSB to RJ45ā€ converter-adapters which are passive-plugs that as a set can easily convert practically any CAT5e/CAT6 shielded Ethernet cable into a very long USB extension cable. See for example these USB extension solutions:
For my current setup this is actually a better solution that Ethernet PoE solution as it has less complexity and fewer things that can go wrong. Note though that 30 meters or 100 feet is the recommended maximum length if you want to use full-speed USB 2.0 data traffic over a such passive cable:
PS: There is by the way a lot more related tips here a most there also applies to Z-Wave as well:
That is a very bad idea in practice because the serial-protocol used by these to communicate between the application and radio is not designed to handle disconnections (you see it was designed using the assumption that the connection is stable), which is why there are warning against using WiFi or WLAN/VPN for Zigbee Coordinator with ZHA. So be warned as you can get serious issues with such a setup unless you have a 100% stable connection all the time. → https://www.home-assistant.io/integrations/zha#other-supported-but-not-recommended-zigbee-radio-adapters-or-modules (and Zigbee2MQTT has a similar warning that also specifically recommoned against connecting a adapter via WiFi/WAN/VPN → Connect to a remote adapter | Zigbee2MQTT )
FYI, if you search you will find several discussions dedicated about such setups, see example:
Counting hours instead of days with less than half a day to wait now! :wink:
You wrote both those warnings yourself! That’s cheating! :wink:
Available for ordering now Home Assistant Connect ZWA-2
Ok. So let’s say a person get a brand new shiny ZWA-2. Is there a good wave to move network from controller_old to controller_zwa2?
EDIT
So at the 1:08:00 point of live stream they go over migration.
I hadn’t finished watching stream and right after I posted I went back to watch and just happened to be at the point where they were going over UI design and migration steps.
Wow, I guess the point of the previous reply flew over your head.
In any case, USB connected isn’t going on my servers with new devices. If it’s not Ethernet and PoE, I’m simply not interested at all.
oof… def gonna have to wait till next pay after some main bills are sorted with that price:
Where are you looking
I see $68 USD at cloudfree
Probably $7? After tax+shipping
