Out of blue I got this error:
Invalid config
The following components and platforms could not be set up:
Please check your config.
I didn’t change a thing and now it no longer works.
Config looks fine.
What should I do?!
It’s August lock connected to August WiFi Hub (August Connect).
By the way, where can I enter the August lock authentication code?!
Per: “Once Home Assistant is started, a configurator will pop up asking you to enter verification code that is sent to your phone number or email.”
Log:
2019-08-20 16:36:30 ERROR (MainThread) [homeassistant.setup] Error during setup of component august
File “/usr/src/homeassistant/homeassistant/setup.py”, line 172, in _async_setup_component
component.setup, hass, processed_config # type: ignore
File “/usr/local/lib/python3.7/concurrent/futures/thread.py”, line 57, in run
File “/usr/src/homeassistant/homeassistant/components/august/init.py”, line 173, in setup
return setup_august(hass, config, api, authenticator)
File “/usr/src/homeassistant/homeassistant/components/august/init.py”, line 119, in setup_august
hass.data[DATA_AUGUST] = AugustData(hass, api, authentication.access_token)
File “/usr/src/homeassistant/homeassistant/components/august/init.py”, line 184, in init
self._doorbells = self._api.get_doorbells(self._access_token) or []
File “/usr/local/lib/python3.7/site-packages/august/api.py”, line 146, in get_doorbells
access_token=access_token).json()
File “/usr/local/lib/python3.7/site-packages/august/api.py”, line 296, in _call_api
response.raise_for_status()
File “/usr/local/lib/python3.7/site-packages/requests/models.py”, line 940, in raise_for_status
raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 401 Client Error: Unauthorized for url: https://api-production.august.com/users/doorbells/mine
