Should we expect the ESPHome Bluetooth Proxies page to typically lag behind what HA is expecting?
For those of us using container, is there an easy way of incorporating the ESPHome Add on dashboard, or at least some over the air upgrade? It would be great if we could upgrade directly from HA!
@bdraco I am running HA container, but just created an ESPHome docker container. This is all new to me. It found my two M5 Atom devices. If I click ADOPT, will it overwrite the firmware I have installed for HA? Or will it just work congruently with HA and I can update to the latest firmware as it is released?
I figured I had nothing to lose, so I adopted them. It reflashed to the same version. Everything is working correctly in HA. So I guess I am good now, and I’ll be able to do over the air updates. Thanks for your help answering all of my annoying questions!
Is there a Raspberry Pi bluetooth proxy (i.e. a separate rpi from the one that runs HA) that uses the built-in rpi bluetooth, or do I have to use an ESP option (or a BT dongle on the rpi)?
