With debug on:
2018-03-19 19:53:31 ERROR (MainThread) [homeassistant.setup] Error during setup of component august
File "/usr/src/app/homeassistant/setup.py", line 148, in _async_setup_component
component.setup, hass, processed_config)
File "/usr/local/lib/python3.6/asyncio/futures.py", line 327, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/local/lib/python3.6/asyncio/tasks.py", line 250, in _wakeup
future.result()
File "/usr/local/lib/python3.6/asyncio/futures.py", line 243, in result
raise self._exception
File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/usr/src/app/homeassistant/components/august.py", line 137, in setup
from august.api import Api
File "/config/august.py", line 22, in <module>
"User-Agent": USER_AGENT,
File "/usr/local/lib/python3.6/site-packages/requests/api.py", line 72, in get
return request('get', url, params=params, **kwargs)
File "/usr/local/lib/python3.6/site-packages/requests/api.py", line 58, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/local/lib/python3.6/site-packages/requests/sessions.py", line 508, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.6/site-packages/requests/sessions.py", line 618, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.6/site-packages/requests/adapters.py", line 440, in send
timeout=timeout
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 601, in urlopen
chunked=chunked)
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 357, in _make_request
conn.request(method, url, **httplib_request_kw)
File "/usr/local/lib/python3.6/http/client.py", line 1239, in request
self._send_request(method, url, body, headers, encode_chunked)
File "/usr/local/lib/python3.6/http/client.py", line 1280, in _send_request
self.putheader(hdr, value)
File "/usr/local/lib/python3.6/http/client.py", line 1212, in putheader
values[i] = one_value.encode('latin-1')
UnicodeEncodeError: 'latin-1' codec can't encode character '\u2013' in position 13: ordinal not in range(256)
2018-03-20 21:41:52 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=persistent_notification, service=create, service_data=title=Invalid config, message=The following components and platforms could not be set up:
- [august](https://home-assistant.io/components/august/)
Please check your config., notification_id=invalid_config, service_call_id=140005444619792-4>
