hello,
i just updated my home assistant to version “core-2021.11.5” I’m using August lock 3
integration via wifi, not zwave
it was working for over a year now but suddenly after updating home assistant it stopped working
i removed it and tried to integrate it again but the same error - usually i asked to enter verifying code i get from email when trying to integrate but i didn’t.
Logger: homeassistant.config_entries
Source: components/august/gateway.py:131
First occurred: November 30, 2021, 9:39:53 PM (2 occurrences)
Last logged: 9:40:59 AM
Error setting up entry [email protected] for august
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 304, in async_setup
result = await component.async_setup_entry(hass, self) # type: ignore
File "/usr/src/homeassistant/homeassistant/components/august/__init__.py", line 43, in async_setup_entry
return await async_setup_august(hass, entry, august_gateway)
File "/usr/src/homeassistant/homeassistant/components/august/__init__.py", line 79, in async_setup_august
await data[DATA_AUGUST].async_setup()
File "/usr/src/homeassistant/homeassistant/components/august/__init__.py", line 137, in async_setup
await self.activity_stream.async_setup()
File "/usr/src/homeassistant/homeassistant/components/august/activity.py", line 42, in async_setup
await self._async_refresh(utcnow())
File "/usr/src/homeassistant/homeassistant/components/august/activity.py", line 92, in _async_refresh
await self._august_gateway.async_refresh_access_token_if_needed()
File "/usr/src/homeassistant/homeassistant/components/august/gateway.py", line 131, in async_refresh_access_token_if_needed
await self.authenticator.async_refresh_access_token(force=False)
File "/usr/local/lib/python3.9/site-packages/yalexs/authenticator_async.py", line 126, in async_refresh_access_token
authentication = self._process_refreshed_access_token(refreshed_token)
File "/usr/local/lib/python3.9/site-packages/yalexs/authenticator_common.py", line 140, in _process_refreshed_access_token
jwt_claims = json.loads(base64.b64decode(jwt_parts[1] + "==="))
File "/usr/local/lib/python3.9/base64.py", line 87, in b64decode
return binascii.a2b_base64(s)
binascii.Error: Invalid base64-encoded string: number of data characters (649) cannot be 1 more than a multiple of 4
Does anyone has the same issue or is it just me?
