Hello!
I have an air purifier - Aura Air, and I recently found out that the manufacturer went bankrupt and the device no longer works.
The purifier can only be controlled from the application.
Is there a solution to control it from Home Assistant?
Thank you!
Hello Serban,
Here is a search with a little information. Not sure it will help.
site:home-assistant.io Aura Air
Hello again
Thanks for the suggestion. I searched but couldn’t find anything to help me.
I’m back with some pictures of the motherboard.
Do you think it can be controlled with esphome or do you see another possible way to control the purifier?
Hello!
I found out that the wm-n-bm-14-s module is produced by WICED.
Can such a device be controlled with this module through the home assistant?
