Aurora Map Card — NOAA OVATION 24h Animation
This custom card shows a smooth 24-hour playback of the NOAA SWPC OVATION aurora forecast, directly in Home Assistant.
You can switch between South and North hemispheres and optionally remember your default.
Installation
- Create the file
/config/www/aurora-map.html
- (Create the
www
folder if it doesn’t already exist.)
- Copy the entire below code snippet into the file you just created
AURORA MAP CARD CODE aurora-map.html
<!doctype html>
<html lang="en">
<head>
<meta charset="utf-8" />
<meta name="viewport" content="width=device-width,initial-scale=1" />
<title>Aurora South – 24h (filename-only)</title>
<style>
:root { color-scheme: dark; }
html,body { height:100%; }
html,body { margin:0; background:#000; color:#e6e6e6; font:14px/1.4 system-ui,Segoe UI,Roboto; }
body.centerY { min-height:100vh; display:flex; align-items:center; }
body.pinTop { min-height:100vh; display:flex; align-items:flex-start; }
*, *::before, *::after { box-sizing: border-box; }
/* Container width like KP card */
.wrap { width: min(960px, 100%); margin-inline:auto; padding:12px; }
/* FLUSH mode: remove the gap entirely */
.wrap.flush { padding: 0 !important; }
/* Viewer: fixed height (360px), full width */
.box { width:100%; height:360px; }
.box > img { width:100%; height:100%; object-fit: contain; display:block; image-rendering:auto; }
.tag {
position:fixed; left:.5rem; bottom:.5rem; color:#ccc;
font:12px/1.2 sans-serif; background:rgba(0,0,0,.45);
padding:.25rem .4rem; border-radius:.3rem;
/* Controls */
.controls {
position: fixed; top:.5rem; right:.5rem; display:flex; gap:.4rem; align-items:center;
font:12px/1.2 system-ui,Segoe UI,Roboto; color:#ddd; user-select:none;
background:rgba(0,0,0,.45); padding:.3rem; border-radius:.35rem;
backdrop-filter: blur(2px);
.controls button {
border:1px solid rgba(255,255,255,.25);
background:rgba(255,255,255,.08);
color:#eee; padding:.25rem .5rem; border-radius:.3rem; cursor:pointer;
.controls button.active { border-color:#9ad; background:rgba(160,200,255,.18); }
.controls label { display:flex; align-items:center; gap:.25rem; opacity:.9; }
.sp { width:.4rem; }
</style>
</head>
<body class="centerY">
<div class="wrap flush">
<div class="box"><img id="frame" alt="NOAA Aurora (24h animated)" /></div>
</div>
<div class="tag" id="stamp">loading…</div>
<div class="controls">
<button id="btn-south" type="button">SOUTH</button>
<button id="btn-north" type="button">NORTH</button>
</div>
<script>
// ---------- Tweakables (static) ----------
const DEFAULT_HEMI = 'south'; // ← set 'south' or 'north' as the default on refresh
let HOURS = 24;
let STEP_MIN = 5;
let JITTER_MIN = 4;
let FPS = 5;
let PRELOAD_AHEAD = 10;
// Hemisphere state
let HEMI = DEFAULT_HEMI;
let PREFIX = HEMI === 'south' ? 'aurora_S' : 'aurora_N';
let BASE = `https://services.swpc.noaa.gov/images/animations/ovation/${HEMI}/`;
const pad2 = (n) => String(n).padStart(2,'0');
const stampName = (d) =>
`${PREFIX}_${d.getUTCFullYear()}-${pad2(d.getUTCMonth()+1)}-${pad2(d.getUTCDate())}_${pad2(d.getUTCHours())}${pad2(d.getUTCMinutes())}.jpg`;
function buildGrid() {
const now = new Date();
const end = new Date(Date.UTC(
now.getUTCFullYear(), now.getUTCMonth(), now.getUTCDate(),
now.getUTCHours(), now.getUTCMinutes() - (now.getUTCMinutes() % STEP_MIN), 0, 0
const start = new Date(end.getTime() - HOURS * 60 * 60 * 1000);
const grid = [];
for (let t = new Date(start); t <= end; t = new Date(t.getTime() + STEP_MIN*60*1000)) {
grid.push(new Date(t));
return { grid, end };
const sweepOrder = [0,1,-1,2,-2,3,-3,4,-4];
function candidateUrls(tBaseUtc) {
const order = sweepOrder.filter(x => Math.abs(x) <= JITTER_MIN);
return order.map(j => {
const tj = new Date(tBaseUtc.getTime() + j*60*1000);
return BASE + stampName(tj);
let resolvedCache = new Map(); // key: ISO -> url|null
function resolveFirstWorking(tUtc) {
const key = tUtc.toISOString();
if (resolvedCache.has(key)) return Promise.resolve(resolvedCache.get(key));
const list = candidateUrls(tUtc);
return new Promise((resolve) => {
let i = 0;
const tryNext = () => {
if (i >= list.length) { resolvedCache.set(key, null); resolve(null); return; }
const url = list[i++];
const im = new Image();
im.onload = () => { resolvedCache.set(key, url); resolve(url); };
im.onerror = tryNext;
im.decoding = 'async';
im.src = url;
tryNext();
const img = document.getElementById('frame');
const tag = document.getElementById('stamp');
const btnSouth = document.getElementById('btn-south');
const btnNorth = document.getElementById('btn-north');
let idx = 0, playing = false;
const FRAME_MS = 1000 / FPS;
let last = 0, acc = 0;
let grid = [];
let playlist = [];
function setButtons() {
btnSouth.classList.toggle('active', HEMI === 'south');
btnNorth.classList.toggle('active', HEMI === 'north');
document.title = `Aurora ${HEMI === 'south' ? 'South' : 'North'} – 24h (filename-only)`;
img.alt = `NOAA Aurora ${HEMI === 'south' ? 'South' : 'North'} (24h animated)`;
function resetForHemi(newHemi) {
HEMI = newHemi;
const built = buildGrid();
grid = built.grid;
playlist = new Array(grid.length).fill(null);
idx = 0;
playing = false;
tag.textContent = 'loading…';
setButtons();
warmFrom(0);
firstPassResolve();
async function firstPassResolve() {
let resolvedCount = 0;
for (let i = 0; i < grid.length; i++) {
const url = await resolveFirstWorking(grid[i]);
if (url) { playlist[i] = { url, t: grid[i] }; resolvedCount++; }
tag.textContent = `resolved ${resolvedCount}/${grid.length}`;
playing = true;
async function warmFrom(startIdx) {
let warmed = 0, i = startIdx;
while (warmed < PRELOAD_AHEAD && i < startIdx + (grid.length || 0)) {
const p = playlist[i % (playlist.length || 1)];
if (p && p.url) {
const im = new Image(); im.decoding = 'async'; im.src = p.url;
warmed++;
i++;
function loop(ts) {
if (!last) last = ts;
const dt = ts - last; last = ts; acc += dt;
if (acc >= FRAME_MS) {
acc -= FRAME_MS;
if (playlist.length) {
let tries = 0;
while (tries < playlist.length && (!playlist[idx] || !playlist[idx].url)) {
idx = (idx + 1) % playlist.length; tries++;
if (playlist[idx] && playlist[idx].url) {
img.src = playlist[idx].url;
if (playing) {
tag.textContent = playlist[idx].t.toISOString()
.replace('T',' ').replace('.000Z',' UTC');
if ((idx % 6) === 0) warmFrom(idx);
requestAnimationFrame(loop);
img.addEventListener('error', () => { idx = (idx + 1) % (playlist.length || 1); });
btnSouth.addEventListener('click', () => resetForHemi('south'));
btnNorth.addEventListener('click', () => resetForHemi('north'));
resetForHemi(HEMI);
</script>
</body>
</html>
- Restart Home Assistant
Required so HA can serve new static files from/local/
Add the Card to Lovelace
Add an iframe card in your dashboard:
type: iframe
url: /local/aurora-map.html?v=1
aspect_ratio: 100%
If in Sections View
type: iframe
aspect_ratio: 100%
grid_options:
columns: 12
rows: 7
Cache Busting
- The
?v=1
at the end forces browsers to reload when you update the file. - Each time you edit
aurora-map.html
, bump the number (?v=2
,?v=3
, …) so you don’t get a stale cached version. - Once the card is loaded you do not have to restart home assistant to refresh, just bump the number.
How It Works
- Buttons: switch between SOUTH and NORTH.
* Remember as default: saves your choice in the browser (localStorage
).- Buttons still override the active hemisphere for the current session (no persistence).
- Added a tweakable
DEFAULT_HEMI
('south' | 'north'
). - On load/refresh, the viewer uses
DEFAULT_HEMI
and lights the matching button.
- Sizing:
- Width: responsive up to 960 px.
- Height: fixed at 360 px for consistency.
- No outer gaps (flush mode).
- Data source: pulls still images from NOAA every 5 minutes, resolving missing frames with a ±4-minute sweep.
- Playback: runs at 5 fps by default, preloading frames for smooth animation.
- Timestamp: bottom-left overlay shows UTC for each frame.
Optional Tuning
Inside the <script>
you can adjust:
let HOURS = 24; // how many hours back
let STEP_MIN = 5; // data cadence (minutes)
let JITTER_MIN = 4; // search window for missing frames
let FPS = 5; // playback speed
let PRELOAD_AHEAD = 10;// preload frames ahead
Credits
- Aurora images courtesy of NOAA SWPC OVATION model.
Data and service availability depend on NOAA’s infrastructure.
