Australia - Electrically Certified Hardware
Would love to this in context, with the rest of the .yaml?
Also, just trying to move them over the ESPhome and getting;
Upload Failed
Upload buffer miscompare
How did you get around that?
EDIT!
If anyone runs into this, its because I upgraded to the full firmware before I went to ESPhome. Just leave it on the minimal, and you will be fine :slight_smile:
Good job figuring it out! Also good to know there arenā€™t unflashable versions on sale (yet).
Hereā€™s my current yaml file to get switching with energy monitoring in Home Assistant via ESPHome. Itā€™s based on the Gosund SP1 config in the ESPHome cookbook here, but using the pins from the Tasmota template here.
Iā€™m no expert so use this at your own risk. That said itā€™s working fine for me on four devices and as mentioned, Iā€™ve tweaked the energy monitoring settings to match an independent power monitor fairly closely.
For newcomers; my first two plugs I flashed with the tasmota-lite firmware bundled with Tuya-convert before compiling the below ESPHome yaml in Home Assistant then flashing it to the device from the Tasmota page on the deviceā€™s IP address. The next two plugs I skipped the tasmota step and flashed the compiled ESPHome firmware directly from tuya-convert which worked fine. Iā€™d recommend the second approach as thereā€™s no need to involve Tasmota.
I noticed the ESPHome implementation makes switching the device almost instant, where Tasmota had a noticeable delay. I also donā€™t see the need to involve an MQTT broker as another point of failure however thatā€™s just personal preference.
ESPHome yaml configuration for an Australian Brilliant Smart Plug with energy monitoring (BL20925)
esphome:
  # Make sure this name is unique for each device
  platform: ESP8266
  board: esp01_1m
wifi:
  ssid: "YourWifiNameHere"
  password: "YourWifiPasswordHere"
  ap:
    ssid: "Monitoring-Plug-1"
    password: "StrongPasswordHere"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
  # Optional password for adding this device to Home Assistant
ota:
  # Optional password for flashing the device over the air from ESPHome
binary_sensor:
  - platform: gpio
    pin:
      number: 3
      mode: INPUT_PULLUP
      inverted: true
    name: "Plug 1 Power Button"
    on_press:
      - switch.toggle: relay
switch:
  - platform: gpio
    pin:
      number: GPIO13
      inverted: true
  - platform: gpio
  # Make sure this name is unique for each device.
  # This is the entity you'll add to a Home Assistant dashboard to control the switch
    pin: GPIO14
  - platform: hlw8012
    sel_pin:
      number: GPIO12
      inverted: True
    cf_pin: GPIO04
    cf1_pin: GPIO05
  # These values can be tweaked to calibrate the energy monitoring.
  # Start with the voltage divider to get the voltage right, then adjust the current resistor to adjust the watts as this relies on the voltage being right.
    current_resistor: 0.00103
    voltage_divider: 2160
    current:
      name: "Plug 1 current"
      unit_of_measurement: A
    voltage:
      name: "Plug 1 Voltage"
      unit_of_measurement: V
    power:
      name: "Plug 1 Wattage"
      unit_of_measurement: W
    # Total energy use may not be very useful as it will be reset if the device looses power, monitoring may be better done in Home Assistant. If needed, uncomment the following lines.
    ##energy:
    ##  name: "Plug 1 Energy"
    ##  unit_of_measurement: Wh
    # How often the device will report energy usage stats to Home Assistant
    update_interval: 60s
    # The initial report mode - useful if not auto-switching between report types, see below.
    initial_mode: CURRENT
    # The hlw8012 energy monitor can only report voltage and watts or amps and watts at a time. This setting will switch between them. If you want to stay on one report type, set the 'initial mode' above, then set 'change mode every' to 4294967295.
    change_mode_every: 8
Allā€™s well that ends well I guess, but still annoyed that I wasted so much time on something thats so easy LOL
Oh well, thanks for giving it another go and making me try it again :slight_smile:
I ended up using this as the template in the end.
Seems to be working well.
Is anyone using Node Red to run automations off of the power drawā€¦ eg have alexa notify you when the washings finished?
Please upload to https://www.esphome-devices.com/
Good idea nick, although it looks like thereā€™s a better version on esphome-devices already that Shane found (donā€™t know how I missed this!).
Could have been worse, you could have missed that they can still be flashed HAHA
Has anyone see this? It wont show the correct voltage, other one works fine. I was thinking about deleting and readding itā€¦ But no idea if that would actually make a difference.
Any ideas?
Thanks guys
EDIT,
Was a faulty plug swapped it out
Sorry if this has been discussed but I couldnā€™t find it in the search.
Does anyone know about a dimmer switch with 4 buttons? I was hoping for something like https://www.bunnings.co.nz/deta-grid-connect-smart-quad-gang-touch-light-switch_p0161015 but with dimmers instead of just buttons.
I was also wondering if anyone knew of any pet-sensitive motion detectors?
Cheers
I have seen the Xiaomi plugs with power monitoring. But I donā€™t know if theyā€™re certified (or even need certification). I have a couple and they work quite well. Trying to get away from the Xiaomi ZigBee stuff though
Anyone know of any others?
Hi Tim, when you get time please share the changes to the fan.py file to modify the speeds.
Also can someone please let me know how to get to this Entity Configuration screen.
Thanks again for your help.
https://www.officeworks.com.au/shop/officeworks/p/brilliant-lighting-smart-wifi-plug-with-energy-monitoring-bl20925
I went for these in the end. Just flashed them with Tuya Convert (Its pretty easy if you have an old Pi Zero W, or other Pi hanging round)
I cant find type I Zigbee plugs hereā€¦ Well for a good price anyway. If youā€™re rich and like to throw money on the street. You can get Hue plugs that should work with Smartthings ect.
Has anyone installed the new Deta single gang dimmable smart switches? Around $54 at Bunnings, same as this but dimmable.
https://www.bunnings.com.au/deta-grid-connect-smart-single-gang-touch-light-switch_p0098811?gclid=Cj0KCQjwi7yCBhDJARIsAMWFScNwrHtCvJ_OoUArSb6cbcdLNCwD4osFwrvv51YYzKh5IP1r4iI8hI8aAjgJEALw_wcB&gclsrc=aw.ds
Keen to know how the dimming function performs!
Iā€™ve been using these with Zigbee2Mqtt. $24 on Ebay for one. Happy with them.
https://www.ebay.com.au/itm/Smart-Power-Plug-Telstra-Smart-Home-Brand-New-Work-with-any-Zigbee-Hub/114271906355?hash=item1a9b22ea33:g:J~oAAOSwQo5e8-Cf
Hey, those plugs look pretty good. Zigbee repeater/extenders as well! Nice find!
Hey mate, can you share your localtuya setup for the Arlec Fan? I have added it with localtuya but am struggling with what ā€œIDā€ to use, and fan control value etc. Cheers
Indeed, good find, have just ordered a few - thanks for the heads up!
I will too - just spent the weekend crafting a CC2530 based router, but this will be much easier (assuming it will work!)
Running with a CC2531 coordinator about 6 months now without any issues.
Can these fit side by side? The pictures it looks a little wide
You wonā€™t get two of them side by side.
