Broadlink RM4 Mini or Sensibo?
You should be right to use the Generic Thermostat integration for that.
I have a technician coming out Friday to take a look - he recommended the Airtouch even though heās a Daikin retailer, said that the individual room controls are a lot better than Airbase as Airbase can only have ~ 2 degrees variation in the system. Heās also a home assistant user so at least he understands what Iām trying to achieve.
@tom_l i recall reading about your solar and aircon automation - what size solar installation do you have to achieve that much excess power?
Through office works or somewhere else?
Just off the Office Works websiteā¦ Same as up hereā¦
For those with the Daikin Airbase interface - is this a cloud based device or is there local access available ?
Also, prices online are around $250 to $300.
Is this around what you paid / expected price ?
Thanks.
Totally local.
Just looked at my quote for the BRP15B61, $350
DHT22 connected to an ESP.
8kW of panels with a 6kW inverter.
I have that same setup too David. SolarEdge 8.25kW 3-phase connected via the HA SolarEdge modbus integration and ethernet.
Way better than their cloud access, which dropped out for me for hours at a time.
Martin
Shifted question to the recently discovered Genio product threadā¦
Damien, Iām using Daikin Airbase on a 3-phase ducted system with 6 outlets.
I have some automations controlling it, to start the system only when there is enough solar power from my inverter to cover the load (usually by 8:30AM in the morning) and the inside temperature is rising above 22C.
Works well for me. Zone opening or closing is also controlled by HA via Airbase
I did have some fun working out which functions applied to my AC unit and the OEM Daikin zone controller, but once sorted itās been great.
Thought Iād share my setup here too - Iād love to hear from anyone else who can add more.
I have three Daikin Cora split systems, different capacities, each with the daikin wifi modules attached.
FTXV95LVMA 9.5kW Cora split system
BRP072C42
Power/mode/temp only (not fan speed, tilt/pan, etc)
FTXV71UVMA 7.1kW Cora split system
BRP072C42 + BRP980B42 auxillary PCB
Power/mode/temp/fan/silent/pan/tilt
FTXV46UVMA 4.6kW Cora split system
BRP072C42 + BRP067A42 auxillary PCB
The limitation on the controllable functions for the higher power (>7.1kW) units is common to the HA integration and the Daikin app. I followed up with Daikin tech support, and the short version is that itās a limitation of the different hardware on those units (I donāt know the details). I asked whether itās something that may be addressed by a firmware update of the wifi module or the AC units themselves (OTA or otherwise) and they said that no, they donāt do firmware updates for the wifi modules - i.e. if it was to be changed it would be a new model, with new model number.
My takeaway from it was that the only way to be able to control the fan speed/pan/tilt using anything other than the provided IR remote is to purchase and use an IR blaster device. So I followed up by asking whether they publish (or would provide) the IR codes, to which she also said no.
I to ask her whether the IR remote sends the full desired state (all settings) on each button press, or just the changed setting, but we struggled to communicate. The answer she gave was that it only sends the change the user inputs. But Iām not confident on that, Especially because afterwards I found sites like this which detail a userās reverse engineering of the messages which contains all of the state options together!
From a HA point of view, I guess using this would involve some sort of template climate entity where (all or some of) the instructions are sent via IR, and the status is pulled directly from the wifi adaptor.
If you are technically inclined one of these is gold for reverse engineering IR or RF serial data devices.
Iāve unlocked quite a few devices with one. The PC software can decode a LOT of common protocols.
You can connect to the LED on the TX, or use an IR diode to detect the serial pulse frames.
Tempted to get one and see if I can work out how to interface to my evaporative A/C via the wall controller.
Iām not sure if that is some sort of knock off or what. The Saleae website has much more expensive versions https://www.saleae.com/
Much more expensive would be a gigantic understatement
One thing the eBay one doesnāt say it includes is software. @mr.sneezy is that the exact unit you have? Did you get software with it for free?
Yeah, I was looking for the software when I found that site. Also interested in the answer.
Yes, my unit is as far as I can tell exactly the same unit, sticker, LEDās and all. Mine runs with Saleae own software. Iām using Logic 2.3.39 with it.
These have been around a long time, I think mine is about 5-6 years old, perhaps this version was an open design at some point.
Also here on Amazon AU
https://www.amazon.com.au/Comidox-Analyzer-Device-Channel-Arduino/dp/B07KW445DJ
Down the bottom it suggests itās also compatible with software called PulseView, but Iāve only ever used Saleae software with mine. Saleae software is free also.
Also found here on a great AU site I buy from for work.
https://core-electronics.com.au/usb-logic-analyzer-25mhz-8-channel-43841.html?
Mine was off Ebay, and was about $10AU at the timeā¦
I see the alternative software supports at least 5 common IR protocol decoders.
https://sigrok.org/wiki/Protocol_decoders
I do like core-electronics but most of their prices are far above what can be bought elsewhere, even within Aus.
Thanks for the info.
Just got emailed with info on a new device, made in Aus too!
I think this is a good deal on the logic analyzer, and they have good buyer feedback.
From doing some checking it seems the open source software is the way to go when using these units, which apparently were all originally based on the main chip datasheet suggested schematic anywayā¦
https://sigrok.org/wiki/Downloads
Iāll try it myself too.
I have 8 of these brilliant ceiling fan controllers and I am having some issues getting the new HA config to work. I used this Brilliant Smart Ceiling Fan Remote in Home Assistant blog post to set them all up and they all work fine. The big diff from this blog post (Taking the old ceiling fan for a smart spin ā neon.ninja) is that it stores the RF data in the HA config file, not in the device (fan) config.
Below is the YAML that was working, is there just a simple way to convert this?
fan:
- platform: mqtt
unique_id: "esp_fan_bedroom"
command_topic: "cmnd/esp_fan_bedroom/POWER1"
state_topic: "tele/esp_fan_bedroom/STATE"
state_value_template: "{{ value_json.POWER1 }}"
speed_command_topic: "cmnd/esp_fan_bedroom/Backlog"
speed_state_topic: "tele/esp_fan_bedroom/RESULT"
speed_value_template: >
{% if value_json.TuyaReceived.Data == "55AA03070005030400010016" %}
Power1 1; TuyaSend4 3,0
{% elif value_json.TuyaReceived.Data == "55AA03070005030400010117" %}
Power1 1; TuyaSend4 3,1
{% elif value_json.TuyaReceived.Data == "55AA03070005030400010218" %}
Power1 1; TuyaSend4 3,2
{% endif %}
availability_topic: tele/esp_fan_bedroom/LWT
payload_available: Online
payload_not_available: Offline
payload_low_speed: "Power1 1; TuyaSend4 3,0"
payload_medium_speed: "Power1 1; TuyaSend4 3,1"
payload_high_speed: "Power1 1; TuyaSend4 3,2"
payload_off: "OFF"
payload_on: "ON"
qos: 1
retain: false
speeds:
- "off"
- low
- medium
- high
I have tried adapting the other configs (which require setting the RF data in the device config) and it just doesnāt work
- platform: mqtt
state_topic: "stat/esp_fan_bedroom/POWER1"
payload_on: "ON"
payload_off: "OFF"
availability_topic: "tele/esp_fan_bedroom/LWT"
payload_available: "Online"
payload_not_available: "Offline"
preset_mode_state_topic: "stat/esp_fan_bedroom/RESULT"
preset_mode_value_template: >
{%- if value == '3,0' %}Low
{%- elif value == '3,1' %}Medium
{%- elif value == '3,2' %}High
{%- endif -%}
preset_mode_command_topic: "cmnd/esp_fan_bedroom/TuyaSend4"
preset_mode_command_template: >
{%- if value == "Low" %}3,0
{%- elif value == "Medium" %}3,1
{%- elif value == "High" %}3,2
{%- endif -%}
qos: 0
preset_modes:
- "Low"
- "Medium"
- "High"
Rules:
Rule1
on TuyaReceived#Data=55AA03070005030400010016 DO Publish stat/esp_fan_bedroom/RESULT {"Speed":1} endon
on TuyaReceived#Data=55AA03070005030400010117 DO Publish stat/esp_fan_bedroom/RESULT {"Speed":2} endon
on TuyaReceived#Data=55AA03070005030400010218 DO Publish stat/esp_fan_bedroom/RESULT {"Speed":3} endon
Rule1 ON
Rule2
on Event#speed=1 DO Backlog Power1 1; TuyaSend4 3,0 endon
on Event#speed=2 DO Backlog Power1 1; TuyaSend4 3,1 endon
on Event#speed=3 DO Backlog Power1 1; TuyaSend4 3,2 endon
Rule2 ON
Running Firmware: Tasmota 10.0.0.4 by Theo Arends
Appreciate any help, as getting hot here as we get into summer, and my family loves them working in Apple Home.
