Hey everyone, just wanted to do a quick sanity check before I finally order some Shelly relays. I’ve seen them working for a two way switch online (like where there’s a switch at each end of the lounge) in American/European set ups and only using 1 Shelly relay. Is there any weird electrical stuff that we have that would make it different? I’ve got 2 two way switches and am trying to figure out if I need 2 relays or 4 total
Ah, perfect, that’s the best news ever! Now to order them and sit patiently (while thinking up my first automations!) until we get an electrician to install
I use a Shelly 1 to switch the Smart Grid (SG) Ready control line on my Stiebel Electron hot water heat pump, which raises the set point from 61°C to 65°C.
I use a Bunnings Deta Smart Grid outdoor socket to switch the compressor circuit on and off and measure power consumption.
I keep the annode circuit powered continuously (4 W) and switch the compressor circuit on when I have excess solar (600W) and it switches off when it detects no power draw for 30 minutes (i.e. the compressor has switched off for 30 minutes).
I check to wait and see if the compressor has stopped by waiting until the power draw has dropped and then switch off. My Stiebel Electron also has a seperate circuit for the annode so I keep that powered continuously.
My heat pump doesn’t have an inbuilt timer so that isn’t always an option.
I replaced the outdoor waterproof sockets with Deta grid connect from Bunnings and use localtuya for switching and power consumption for the pool and hot water systems.
I haven’t had much luck with localTuya (no new device adds to the integration any more and I can’t get my older devices to connect either) and so I have abandoned any consideration of using Tuya devices. There are a few that remain operating but once they die, I’ll ditch Tuya/localTuya entirely. It’s just too flakey and too much of a PITA to troubleshoot.
Hi guys,
I have just discovered Hive Mind. Stu puts out some great videos that are easy to follow. His tuya one helped me with my inkbird 308 setup. Would be great if there was some way to get together locally with other HA users to thrash out ideas etc.
Pat
Im running the Deta Grid Connect Smart Outdoor Double Powerpoint (6294HA) flashed with ESPHome (via Libretuya). Fairly straightforward to do. Initial flash was tricky, only because the TX pin was connected to the power monitor chip. So had to make a small cut of the trace, do initial flash, then small ‘repair’ of trace. I pretty much run all my stuff on ESPHome these days. Never touched Tuya.
I have been following ‘Hive Mind’ also on you tube. Good to see a local give it a go - figure we all should subscribe at least and check out his channel.
Start here : https://docs.libretuya.ml
I once was a Tasmota fan, then I moved to ESPHome. Then found some devices without ESP chips so I did a few successful chip transplants. Learnt a lot. Was entertaining for me as I like picking up new skills.
Then I found LibreTuya with ESPHome. That’s been my journey.
