have a look at QuinLED, they are DIY controller boards for LED strips (digital and analogue) that work with ESPHome and WLED.
He’s designed the PCB and published the BOM (parts list) and you have to get them manufactured yourself via his links. He has designs for analogue “dumb” LED strips (see hardware guide), as well as the smart individually addressable type. He has examples to run with ESPHome and WLED.
His PCBs are designed to plug in Wemos D1 Mini (ESP8266) boards, as well as MH-ET D1 Mini 32 (ESP32).
Hello again from NZ. I have searched the thread, but cannot see any reference to this device. My apologies if I missed it! Does anyone know if the Deta Smart Inline Switch With Grid Connect can be flashed with esphome or tasmota?
Also can you control it with a low voltage connection, like using GPIO14 on a sonoff basic?
Well, buy it, open it, if there is nothing there that can be attached take it back.
Bunnings dont ask question when you return it.
I buy stuff all the time i end up returning.
functionally it just like the “rewireable plug” and the “plug base”, which converted without any problem. Hopefully, it more like a shelly (than a sonoff basic) and can take a switch input.
So are these Deta plugs rewireable by Joe Average?
Cannot find anything on the packaging or website that says anything about it requiring a qualified electrician, however, everything you read says you cannot wire something that plugs into mains without being qualified to do so.
All the other Deta packaging references requiring an electrician to install but is missing from this particular plug.
Do you have a link? I don’t see it on their website. When I ask in my local (about a month ago) because they had in on display in their new smart home display, they says it a promotion item not in NSW. Things are changing fast, and now the web site has 3 & 4 gang deta switches that did not exist a few weeks ago,
I found it via the powerpass app, can’t find it on their actual website but the app has more smart items than website… again it did say Oakleigh had stock but I haven’t visually confirmed it… if you give me a postcode and I can search your local bunnings
@diramu If you’re looking for a quick way to search Bunnings stock, a link I got recently from OzBargin is this crude stock searcher. Just provide the item number or URL. It should be the same stock as on the PowerPass app. http://projectsuit.com/bunnings_checker.php
I was in bunnings Alexandria yesterday and it was on display in there smart home display, plug base, plug for the lead, and the inline module, but that doesnt mean they had stock
ACT
Store Stock Message
Tuggeranong 4 In stock
VIC
Store Stock Message
Caroline Springs 4 In stock
Hastings 4 In stock
Mornington 4 In stock
Morwell 4 In stock
Oakleigh 4 In stock
SA
Store Stock Message
Victor Harbor 4 In stock
Without this reference, you have no idea what to search on. If you look up an existing item on the web site, you can’t find a I/N to use. Correction, the numbers on the end of the url for a product is the I/N. Also when to use the find-in-store view more store, it gives you the I/N. And they appears to be same as the NZ site.
