Thanks Tom, will give it a try - just d/loaded in raw format before and has never been an issue. Still just wants to create the one sensor. No dramas will roll back to an older version.
What happens if you remove the fire danger ans UV alert monitored conditions?
Good pick up Tom - it appears the UV and Fire Danger attributes are the issue. I use the UV rating to send alerts, so still need to roll back to older version unfortunately.
what do you mean by this?
I meant an output like this:
12°C to 20°C
Mostly sunny.
This is the solution for single quoted scalars according to the YAML docs :
forecast_days: 6
rest_of_today: True
friendly_state_format: '{min}°C to {max}°C
{summary}'
text_if_no_value: '-'
monitored_conditions:
- 'max'
But it does not work.
@sparkydave, Just realised that isnāt going to work for forecasts like this ā2 to 8 mmā.
yeah, I looked into that tonight and tried an example. It seemed to giive me the first value
It should be possible to extract the max value if that is more use. But it would need a conditional statement to look for ātoā in the string.
Apologies if I am hijacking this thread, but have any Aussies here been able to get pollen/allergy info from anywhere? I thought there might be info on the BOM site and could be extracted as described above but I couldnāt find it. Any help or direction would be greatly appreciated. Thanks
I donāt think BOM do pollen forecasts, you could try this website but they mostly only cover Victoria:L
weather.com seems to have info for everywhere Iāve looked for a pollen count, but I donāt know where they get their data from, so I havenāt used it. Also WeatherZone has info for the capital cities, but for me itās too far away.
Time to build your own pollen sensor!
This is great. Many thanks Brendan!
Thanks for doing these, super helpful!
Came here looking for this info too - it would be rather awesome if we could get current weather warnings. Iād like to potantially set some lights to red or something similar of a current warning for my area was present (hopefully giving a heads up for giant hail etcā¦).
Is anyone else running the dev branch of this and getting the same AttributeError: 'NoneType' object has no attribute 'text'
error that @grantc and @tom_l discussed above?
It looks like disabling the UV and fire danger conditions stop this, but my understanding is that the dev branch exists to add support for this?
Thanks for some fantastic work. Iāve got this working well on my Sunology, using Docker, and 0.85.0 of Home Assistant
Hi all, Iām a bit of a noob, and having trouble with the n/a to n/a issue. Could anyone help me out with a ādummies guideā to fixing it?
Here is my config:
> #Sensors
> #weather stuff
> sensor:
> - platform: bom_forecast
> product_id: IDV10450
> forecast_days: 3
> rest_of_today: True
> friendly: True
> friendly_state_format: '{min} to {max}'
> - 'max'
> - 'min'
> - 'chance_of_rain'
> - 'possible_rainfall'
> - 'summary'
> - 'detailed_summary'
The problem is, ān/aā is referring to the minimum temp or low temp for that day. If it is ātodayā then the lowest temp has already past, it wouldāve occurred at some time before sunrise. So BoM donāt publish that low in their āforecastā because it is not actually a āforecastā, it is historical. To overcome this you could create a template sensor that is based on the value for ātodayā but removes the n/a section of the value. Hope this helps.
Hey, thanks for the reply. Iāve never worked with template sensorās before, is there a example for this I can work off?
