Australian Weather Forecast using BOM Public FTP
Hi All,
First off, credit to @enzymes in this thread for inspiring me to do this work. I am not a developer, and this is my first exposure to Python, so hopefully I have created something at least partially useful for the Australian Home Assistant community. I am completely open to feedback and would love to make something that is used by our community
So it seems the BoM have recently started detecting and blocking web scrapers, fortunately they also provide an open, public FTP service. Unfortunately, Home Assistant doesn’t have an FTP component already. This is where I have tried to fill in the gap with my custom component, bom_forecast.
Please follow the setup instructions on github:
Friendly mode?
  • Friendly mode will avoid creating a sensor for each individual condition for each day of forecast and will neatly present each forecast day as one sensor.
Tried this through the Appdaemon app you release a week ago and still getting the same error now. Am I the only one getting this issue? Thanks again for your efforts Brendan.
2018-10-02 11:58:47 ERROR (MainThread) [homeassistant.components.sensor] Error while setting up platform bom_forecast
File “/srv/homeassistant/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py”, line 128, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=hass.loop)
File “/usr/lib/python3.6/asyncio/tasks.py”, line 358, in wait_for
return fut.result()
File “/usr/lib/python3.6/concurrent/futures/thread.py”, line 56, in run
File “/home/homeassistant/.homeassistant/custom_components/sensor/bom_forecast.py”, line 134, in setup_platform
bom_forecast_data.update()
File “/srv/homeassistant/lib/python3.6/site-packages/homeassistant/util/init.py”, line 324, in wrapper
result = method(*args, **kwargs)
File “/home/homeassistant/.homeassistant/custom_components/sensor/bom_forecast.py”, line 295, in update
open(‘bom_forecast.xml’, ‘wb’).write)
PermissionError: [Errno 13] Permission denied: ‘bom_forecast.xml’
Hmmm
 looks like on hass.io there is no permission to create files on the local system. I will have to come up with another way! Thanks for the feedback Grant.
That looks promising, I will have a try tonight
 great work!
I saw another weather related chat talking about weather alarms. Is it possible to have these weather warnings/events triggered with this as well ?
you can save to the local system but the directory needs to in the ‘whitelist’. I’ll be keen to try this out next week when I get the time
Working perfectly for me (Hassio).
This would be why it is working for me then. I have:
  whitelist_external_dirs:
    - /config
I have updated the code on github so that it doesn’t attempt to write a file to disk, it will store it in memory rather than save the file. Give it a go now.
Tried the whitelist option with no luck and now your revised version seems to have worked. Cheers
How did you do the weather code Tom?
Which one David?
The graph with temp/dewpoint
 bottom left
It’s a history graph of the BoM Australia sensors
groups.yaml
weather_now:
  entities:
  - sensor.bom_hobart_air_temp_c
  - sensor.bom_hobart_feels_like_c
  - sensor.bom_hobart_wind_speed_kt
  - sensor.bom_hobart_wind_gust_kt
  - sensor.bom_hobart_wind_direction
  - sensor.bom_hobart_dew_point_c
  - sensor.bom_hobart_pressure_mb
  - sensor.bom_hobart_rain_today
  - sensor.bom_hobart_relative_humidity
  - history_graph.weather
history_graphs.yaml
weather:
  entities:
  hours_to_show: 72
  refresh: 300
sensors.yaml
- platform: bom
  station: IDT60901.94970
  monitored_conditions:
    - apparent_t
    - gust_kt
    - air_temp
    - dewpt
    - press
    - rain_trace
    - rel_hum
    - wind_dir
    - wind_spd_kt
that looks awesome! How often does your radar update? I take it that you haven’t got the animated version in HA? I had to use the animated radar from another provider because I couldn’t figure a way to import the BOM one properly
No it’s not animated. Just the latest snapshot of the radar using the generic camera component:
- platform: generic
  still_image_url: http://www.bom.gov.au/radar/IDR761.gif?{{ now().strftime("%Y%m%d%H%M") }}00
  limit_refetch_to_url_change: true
yeah I use the same Tom but didn’t know about the limit_refresh! cool.
This is awesome! Stoked to have BOM forecasts back. Mine wasn’t working initially. I did a few hassio restarts and still wasn’t working. Then I just tried a hard reboot and voila! Thanks for your work!
Thanks heaps for your efforts with this. Will be using this heaps.
At the moment, though, I’m getting this error (with hassio, whitelist enabled, updated python code:
Wed Oct 03 2018 08:03:18 GMT+1000 (Australian Eastern Standard Time)
INFO:homeassistant.util.package:Attempting install of colorlog==3.1.4
Testing configuration at /config
ERROR:homeassistant.scripts.check_config:BURB
  File "/usr/local/lib/python3.6/site-packages/homeassistant/scripts/check_config.py", line 207, in check
    res['components'] = check_ha_config_file(hass)
  File "/usr/local/lib/python3.6/site-packages/homeassistant/scripts/check_config.py", line 372, in check_ha_config_file
    platform = loader.get_platform(hass, domain, p_name)
  File "/usr/local/lib/python3.6/site-packages/homeassistant/loader.py", line 60, in get_platform
    return get_component(hass, PLATFORM_FORMAT.format(domain, platform))
  File "/usr/local/lib/python3.6/site-packages/homeassistant/loader.py", line 92, in get_component
    module = importlib.import_module(path)
  File "/usr/local/lib/python3.6/importlib/__init__.py", line 126, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 994, in _gcd_import
  File "<frozen importlib._bootstrap>", line 971, in _find_and_load
  File "<frozen importlib._bootstrap>", line 955, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 665, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 674, in exec_module
  File "<frozen importlib._bootstrap_external>", line 781, in get_code
  File "<frozen importlib._bootstrap_external>", line 741, in source_to_code
  File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
  File "/config/custom_components/sensor/bom_forecast.py", line 9
    <!DOCTYPE html>
SyntaxError: invalid syntax
Fatal error while loading config: invalid syntax (bom_forecast.py, line 9)
Failed config
  General Errors:
    - invalid syntax (bom_forecast.py, line 9)
Successful config (partial)
Hi Adam, looks like some HTML code from github has snuck in there. Try copying the code from this link:
https://raw.githubusercontent.com/bremor/bom_forecast/master/custom_components/sensor/bom_forecast.py
Github is a bit of a bugger to get code from. You have to open the file and then click on raw and save as
 otherwise you get this happening.
