Getting this in my log, running latest on docker / Debian - can someone tell me what I am doing wrong, my config is listed below. The integrations I’m using don’t accept authentication tokens, unless I’m missing something.
2019-09-05 09:53:03 WARNING (MainThread) [homeassistant.components.http.view] Access from trusted networks without auth token is going to be removed in Home Assistant 0.96. Configure the trusted networks auth provider or use long-lived access tokens to access /api/events/wirelesstag_update_tags from 192.168.1.100
2019-09-05 09:54:51 WARNING (MainThread) [homeassistant.components.http.view] Access from trusted networks without auth token is going to be removed in Home Assistant 0.96. Configure the trusted networks auth provider or use long-lived access tokens to access /api/states/binary_sensor.AtticCamera from 192.168.1.81
auth_providers:
- type: trusted_networks
trusted_networks:
- 192.168.1.0/24
- 52.201.207.152
- type: homeassistant
