I am running Home Assistant, Eclipse-Mosquitto, and OpenZWave (ozwdaemon) in docker and using ozw (OpenZWave) and mqtt integrations. I would like to use certificate based authentication, rather than username and password, to authenticate MQTT clients. Here are some relevant entries from my configuration:
Eclipse-Mosquitto: mosquitto.conf
port 8883
cafile /mosquitto/certs/ca.crt
certfile /mosquitto/certs/server.crt
keyfile /mosquitto/certs/server.key
require_certificate true
use_identity_as_username true
Home Assistant: configuration.yaml
mqtt:
port: 8883
certificate: /config/certs/ca.crt
client_key: /config/certs/client.key
client_cert: /config/certs/client.crt
Docker-Compose: openzwave service
openzwave:
environment:
- MQTT_PORT=8883
- MQTT_TLS=true
The mqtt integration seems to support certificate based authentication, but the OpenZWave integration does not. It doesn’t seem like the underlying ozwdaemon project supports certificate based authentication at this time.
Has anyone successfully enabled certificate based authentication for OpenZWave integration or am I out of luck until this feature is added to ozwdaemon?
