Authentication Error
I am running AppDaemon3 in Hassio and getting this error.
2018-02-22 12:36:49.507744 INFO AppDaemon: HASS: Connected to Home Assistant 0.63.3
2018-02-22 12:36:49.534446 WARNING AppDaemon: HASS: Error in authentication
2018-02-22 12:36:49.539240 WARNING AppDaemon: HASS: Disconnected from Home Assistant, retrying in 5 seconds
I am sure it has somethign to do with duck dns and letsencrypt. Here is my config. It looks right from all the examples i have seen but no go.
secrets: /config/secrets.yaml
log:
logfile: STDOUT
errorfile: STDERR
appdaemon:
disable_apps: 0
threads: 10
app_dir: /config/appdaemon/apps
api_ssl_certificate: /ssl/fullchain.pem
api_ssl_key: /ssl/privkey.pem
plugins:
HASS:
type: hass
ha_url: https://xxxxxxxx.duckdns.org:8123
ha_key: !secret hadash_password
cert_path: /ssl/fullchain.pem
cert_verify: False
namespace: default
hadashboard:
dash_url: http://192.168.2.70:5050
dash_dir: /config/appdaemon/dashboards
Test dashboard loads but can’t find the enitiys. :frowning:
Looks like It had something to do with password length. Once I changed the password and rebooted everything it is working.
combed through the code and it’s because you might have a number only password which gets casted as a number instead of a string. Someone should maybe file a bug.
thats just yaml behaviour, not a bug.
possible options are to put quotes around it, or andrew could put in a check if its a string or not.
