I am attempting to define a rest_command which will have the same effect as this successful curl command executed from a command line:
curl -X POST -H "Authorization: Bearer xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx" \
-H "Content-Type: application/json" \
-d '{"state": "on"}' \
"http://192.168.xxx.xxx:8123/api/states/light.study_light"
When I attempt the same by defining a rest_command and calling it from dev-service, I get the following error.
2019-02-26 16:14:55 WARNING (MainThread) [homeassistant.components.rest_command] Error 401 on call http://192.168.xxx.xxx:8123/api/states/light.study_light.
I have tried these three constructions, two with the same access token (with an without a prefix of Bearer) as used with the curl command and one with the legacy api password:
set_study_light_on:
method: POST
url: "http://192.168.xxx.xxx:8123/api/states/light.study_light"
headers:
content-type: application/json
authorization: "Bearer xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
payload: '{"state": "on"}'
set_study_light_on_2:
method: POST
headers:
authorization: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
set_study_light_on_3:
method: POST
headers:
password: !secret http_pw
All fail with the same error message.
I assume that this may have something to do with the authentication (authorization or password) header. The docs https://www.home-assistant.io/components/rest_command/ give an example of usage with an access token, but the token itself is only shown as:
authorization: !secret rest_headers_secret
It does not show the format of the token.
Any tips?
Thanks!
