Authentication invalid
Hello, can someone help me? After flashing usb, compiling and starting to upload I get this error
“ERROR Error auth result: Error: Authentication invalid. Is the password correct?” any ideas ?
I don’t know what to do . ty
Get the password right :slight_smile:
hehe, when flashing they give me the key, and that is the one I paste to compile, I don’t understand it
this is the log
INFO ESPHome 2024.2.0
INFO Reading configuration /config/esphome/tx-ultimate.yaml…
WARNING GPIO5 is a strapping PIN and should only be used for I/O with care.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See Frequently Asked Questions — ESPHome
WARNING GPIO15 is a strapping PIN and should only be used for I/O with care.
WARNING GPIO2 is a strapping PIN and should only be used for I/O with care.
INFO Detected timezone ‘Europe/Madrid’
INFO Starting log output from 192.168.2.167 using esphome API
INFO Successfully connected to tx-ultimate @ 192.168.2.167 in 0.051s
WARNING tx-ultimate @ 192.168.2.167: Connection error occurred: tx-ultimate @ 192.168.2.167: Invalid encryption key: received_name=tx-ultimate
WARNING Can’t connect to ESPHome API for tx-ultimate @ 192.168.2.167: Error while finishing connection: Finishing connection cancelled due to fatal exception: tx-ultimate @ 192.168.2.167: Invalid encryption key: received_name=tx-ultimate: received_name=None (InvalidEncryptionKeyAPIError)
