Hi everyone!
I’m trying to create a RESTful sensor with the following code in sensor.yaml
- platform: rest
name: Current Sales 1
resource: https://statistics-api.wildberries.ru/api/v1/supplier/orders
params:
dateFrom: "2023-10-23T14:45:00"
flag: 0
headers:
Authorization: !secret current_s
accept: application/json
value_template: " {{ value_json.message }} "
timeout: 5
scan_interval: 1800
Instead of getting the info from the API I’m getting the following message, indicating the problem with authorisation error Code 401:
07e4668e-a53a3d31f8b0-UK:dHP4D4TKTpg unauthorized, rejected; 84bd353bf-75 token problem; token is malformed: could not base64 decode signature: illegal base64 data at input byte 43
At the same time, when I issue the following command, the info is fetched without a problem:
curl -X ‘GET’
‘https://statistics-api.wildberries.ru/api/v1/supplier/orders?dateFrom=2023-10-23T10%3A45%3A00&flag=0’
-H ‘accept: application/json’
-H 'Authorization: The token goes here
Can someone tell me what am I doing wrong?
