I created an automation to fade the brightness of all lights that are on with user specified start and stop times for both fade in and fade out as well as minimum and maximum brightness values. I took inspiration from another thread found here.
The whole setup requires a few input_datetime’s, an input_boolean and a couple input_numbers. A template sensor is also required along with the automation itself. Below is the code for all those items. It looks complicated and it sort of is but once you understand what is being done, its much easier to digest. There may be a better way to achieve what this does and I’d be happy to take suggestions for improvement.
Below is the lovelace card and its code I use.
entities:
- entity: input_boolean.global_brightness
- entity: input_number.day_brightness
icon: 'mdi:white-balance-sunny'
- entity: input_number.night_brightness
icon: 'mdi:weather-night'
- entity: input_datetime.fade_in_start
- entity: input_datetime.fade_in_stop
- entity: input_datetime.fade_out_start
- entity: input_datetime.fade_out_stop
show_header_toggle: false
title: Global Light Brightness Settings
type: entities
Automation: All lights need to be manually entered as a trigger for the brightness to be set at the time of it being turned on.
- alias: 'Autoadjust brightness When Turned On' #When a light is turned on adjust to appropriate dim level
initial_state: true
##################LIGHTS####################
- platform: state
entity_id: light.back_porch_inside_light
to: 'on'
- platform: state
entity_id: light.bathroom_light
to: 'on'
- platform: state
entity_id: light.stairs_light
to: 'on'
################^^LIGHTS^^##################
- platform: state
entity_id: sensor.template_global_light_brightness
- platform: state
entity_id: input_boolean.global_brightness
- platform: state
entity_id: input_number.day_brightness
- platform: state
entity_id: input_number.night_brightness
- platform: state
entity_id: input_datetime.fade_in_start
- platform: state
entity_id: input_datetime.fade_in_stop
- platform: state
entity_id: input_datetime.fade_out_start
- platform: state
entity_id: input_datetime.fade_out_stop
- service: light.turn_on
data_template:
entity_id: "{{ states.light | selectattr('state', 'eq', 'on') | map(attribute='entity_id') | join(',') }}"
brightness: >-
{% if states.input_boolean.global_brightness.state == 'off' %}
{{trigger.entity_id.attributes.brightness}}
{% else %}
{{ (states.sensor.template_global_light_brightness.state) }}
{% endif %}
Template Sensor: The sensor refreshes every minute allowing it to be used as a trigger for the automation when its state/value changes.
sensors:
template_global_light_brightness:
friendly_name: Global Light Brightness
value_template: >-
{% if states('sensor.time') and states.input_boolean.global_brightness.state == 'off'%}
{% elif (( now().hour ) * 60 |float) + ( now().minute ) < (states.input_datetime.fade_in_start.attributes.hour * 60) + (states.input_datetime.fade_in_start.attributes.minute) %}
{{ (states.input_number.night_brightness.state|float * 255 / 100) | round(0)}}
{% elif (( now().hour ) * 60 |float) + ( now().minute ) < (states.input_datetime.fade_in_stop.attributes.hour * 60) + (states.input_datetime.fade_in_stop.attributes.minute) %}
{{((((now().hour * 60 + now().minute)-(states.input_datetime.fade_in_start.attributes.hour * 60 + states.input_datetime.fade_in_start.attributes.minute)) / ((states.input_datetime.fade_in_stop.attributes.hour * 60 + states.input_datetime.fade_in_stop.attributes.minute) - (states.input_datetime.fade_in_start.attributes.hour * 60 + states.input_datetime.fade_in_start.attributes.minute)) * ((states.input_number.day_brightness.state|float) - (states.input_number.night_brightness.state|float)) + (states.input_number.night_brightness.state)|float) * 255 / 100) | round(0)}}
{% elif (( now().hour ) * 60 |float) + ( now().minute ) < (states.input_datetime.fade_out_start.attributes.hour*60) + (states.input_datetime.fade_out_start.attributes.minute) %}
{{ (states.input_number.day_brightness.state|float *255 /100) | round(0)}}
{% elif (( now().hour ) * 60 |float) + ( now().minute ) < (states.input_datetime.fade_out_stop.attributes.hour*60) + (states.input_datetime.fade_out_stop.attributes.minute) %}
{{((((states.input_datetime.fade_out_stop.attributes.hour * 60 + states.input_datetime.fade_out_stop.attributes.minute)-(now().hour*60 + now().minute)) / ((states.input_datetime.fade_out_stop.attributes.hour * 60 + states.input_datetime.fade_out_stop.attributes.minute) - (states.input_datetime.fade_out_start.attributes.hour * 60 + states.input_datetime.fade_out_start.attributes.minute)) * ((states.input_number.day_brightness.state|float) - (states.input_number.night_brightness.state|float)) + (states.input_number.night_brightness.state)|float) * 255 / 100) | round(0)}}
{% else %}
{% endif %}
Input Datetime:
input_datetime:
#Light Brightness global fade settings
fade_in_start:
name: Fade in Start Time
has_date: false
has_time: true
fade_in_stop:
name: Fade in Stop Time
has_date: false
has_time: true
fade_out_start:
name: Fade out Start Time
has_date: false
has_time: true
fade_out_stop:
name: Fade out Stop Time
has_date: false
has_time: true
Input Number:
input_number:
day_brightness:
name: Day Brightness
initial: 100
min: 1
max: 100
step: 1
unit_of_measurement: '%'
night_brightness:
name: Night Brightness
initial: 1
min: 1
max: 100
step: 1
Input Boolean
input_boolean:
global_brightness:
name: Global Brightnes
initial: on
Let me know if this was useful to you or if you have any suggestions for how I could improve it for my setup.
