1st time running the HA AIO installer, HA found my Directv boxes.
I’ve since updated HA and I noticed that the Directv boxes are no-longer showing up on the main screen. Has this happened to anyone else?
Going to make sure the Directv is logged into my Home network to be sure.
Master DirecTV receivers (ie: those that have tuners) will be automatically discovered if you enable the discovery component and the receiver is powered-on. Slave/RVU client/Genie boxes will also be discovered, but only if they are also online at the time of discovery.
I highly recommend hard coding your configuration and assigning static IP to your devices. It avoids issues like this as everything is explicitly assigned.
