Some background behind this
The family of the household like to go around flipping off lights by the physical switches. This causes issues with automations and lighting. There’s also the problem with some lights where if you turn them off and back on, they are set to turn on to 100% brightness. I set up multiple sensors for my lights to determine if the lights are too bright and built the automations one by one for each light and area. I know there are better ways to go about building this but it works for now.
Inside of sensors.yaml, you will need to add the sensor for the entity. I’m sure there’s a way to set this programatically and would love to see improvements or suggestions on how to achieve that.
brightlight_testbulb:
friendly_name: Light TestBulb is Over Limit
value_template: >-
{% if state_attr('light.test', 'brightness') | float > 155 %}
true
{% else %}
false
{% endif %}
The blueprint allows to set the transition time and target brightness. I’m going to add a few more options later. Since this is my first blueprint, I thought it would be best to keep things simple.
blueprint:
name: Light is too bright
description: The target entity or group of lights is over the predetermined brightness as set in sensors.yaml
domain: automation
input:
description: Custom sensor in sensors.yaml
selector:
entity:
domain: sensor
target_light:
description: The lights to reduce brightness
selector:
entity:
domain: light
transition_time:
name: Transition time in seconds
default: 30
selector:
number:
min: 0
max: 300
unit_of_measurement: seconds
brightness_percent:
name: Brightness Percentage
default: 10
selector:
number:
min: 1
max: 100
unit_of_measurement: "%"
mode: slider
- platform: state
entity_id: !input sensor
- service: light.turn_on
target: !input target_light
transition: !input transition_time
brightness_pct: !input brightness_percent
