I did multiple installations and formats of machine. at one point discovery was working as I could find my Samsung wifi printer and other devices but with the latest clear installation, my hassio setup cannot find any devices automatically.
I have also tried entering discovery: in configuration.yaml and restarted the server multiple times.
I can detect my ZigBee devices and chromecast devices but none that works on multicast e.g. my three yeelights, printer, etc. I can see zeelights broadcasting their ip address on multicast but not being detected on hassio.
I also read " Home Assistant must be on the same network as the devices for UPnP discovery to work. If running Home Assistant in a [Docker container] use switch --net=host to put it on the host’s network."
but not sure where to put this flag whilst running the docker as per step b above.
also to add, the ip address of my machine is 192.168.x.x whereas hassio in docker is running on 172.30.32.2… I have been able to find google cast devices though…
The thing is: I just installed using the default configs. Linux, ubuntu 64 on a VM, done. I didn’t installed a docker (in fact I doesn’t even know what a docker is), but when I run “network info” on console, I can see this. Different IPs for docker and machine… I don’t know where can I find the docker-compose. In config folder doesn’t have this file :s
