As a lot of other users, Iām using some Shelly devices for my home automation.
When debugging, flashing firmware or no matter what, Iām using the Shelly built-in web interface. Mainly because itās user friendly and it offers more options than the app.
For now, Iāve been using a static entities-card to reach the devices (all static IP adresses):
entities:
- icon: 'mdi:power-plug-outline'
name: Smart Plug Boiler
type: weblink
url: 'http://192.168.68.xxx/'
...etc...
Although it works fine, it stillā¦wellā¦static and all Shelly devices publish their IP-adress on MQTT, so it is stored in sensor.shelly_xxx_ip
Building a list is fairly simple and works perfectly:
type: 'custom:auto-entities'
card:
type: entities
title: Smartplugs
filter:
include:
- entity_id: sensor.shelly*ip
But its still just an entities-card, so not clickable.
Iāve been trying with custom:template-entity-row
but no success.
Option 1: make all entities weblinks, but how to get the entity value in the url-field? Iāve found that this field is not template-able. The entity sensor.shelly*ip just has a state (the IP adress) and a friendly_name attribute.
card:
type: entities
title: Network
filter:
include:
options:
type: weblink
url: ???
Option 2: use custom:template-entity-row
and set the tap-action but same problem here. This is also not useable for option one because you would get 2 type
definitions.
card:
type: entities
title: Network
filter:
include:
options:
type: 'custom:template-entity-row'
tap_action:
action: url
url_path: ???
Any suggestions from the community?
