anyone else noticing small gaps surrounding an auto-entities config like these all of a sudden: https://github.com/thomasloven/lovelace-auto-entities/issues/173
only thing changed is HA, and auto-entities
The following code worked perfectly ok until upgrade to 1.8.2 It kills the lovelace page containing this code. Removing it restores the remainder of the page. Any guidance to point me to the necessary correction would be appreciated:
card:
title: GAD
type: entities
entities:
- entities:
- entity: input_boolean.notify_utility
- entity: input_datetime.gad_notification_time
head:
label: Notification Settings
type: section
padding: 0
type: 'custom:fold-entity-row'
filter:
include:
- entity_id: sensor.gad_restafval
- entity_id: sensor.gad_gft
- entity_id: sensor.gad_papier
- entity_id: sensor.gad_pmd
- entity_td: sensor.gad_textiel
show_empty: false
show_header_toggle: false
sort:
attribute: Sort-date
method: attribute
numeric: true
title: GAD
type: 'custom:auto-entities'
As a lot of other users, Iām using some Shelly devices for my home automation.
When debugging, flashing firmware or no matter what, Iām using the Shelly built-in web interface. Mainly because itās user friendly and it offers more options than the app.
For now, Iāve been using a static entities-card to reach the devices (all static IP adresses):
entities:
- icon: 'mdi:power-plug-outline'
name: Smart Plug Boiler
type: weblink
url: 'http://192.168.68.xxx/'
...etc...
Although it works fine, it stillā¦wellā¦static and all Shelly devices publish their IP-adress on MQTT, so it is stored in sensor.shelly_xxx_ip
Building a list is fairly simple and works perfectly:
card:
type: entities
title: Smartplugs
filter:
include:
- entity_id: sensor.shelly*ip
But its still just an entities-card, so not clickable.
Iāve been trying with custom:template-entity-row
but no success.
Option 1: make all entities weblinks, but how to get the entity value in the url-field? Iāve found that this field is not template-able. The entity sensor.shelly*ip just has a state (the IP adress) and a friendly_name attribute.
card:
type: entities
title: Network
filter:
include:
options:
type: weblink
url: ???
Option 2: use custom:template-entity-row
and set the tap-action but same problem here. This is also not useable for option one because you would get 2 type
definitions.
card:
type: entities
title: Network
filter:
include:
options:
type: 'custom:template-entity-row'
tap_action:
action: url
url_path: ???
Any suggestions from the community?
I just started playing with this card and itās not behaving as Iād expect. In my case, Iām using it for to display info about my 3D printer. Thereās a printer error sensor that is āOffā if no error is present. Thatās really the only entity I care about hiding, so Iām attempting to filter and exclude sensors in state āOff.ā
card:
type: entities
entities:
- entity: binary_sensor.ender_3_project_printing_error
secondary_info: last-updated
- entity: sensor.ender_3_project_job_percentage
name: Print Completion
icon: 'mdi:file-percent-outline'
- entity: sensor.octoprint_time_elapsed_format
icon: 'mdi:clock-start'
name: Printing Time Elapsed
- entity: sensor.octoprint_time_remaining_format
name: Printing Time Remaining
icon: 'mdi:clock-end'
filter:
exclude:
- state: "Off"
Iāve gone into Developer Tools and checked the state just to be sure⦠and it is, in fact, āOff.ā
Do I have a syntax problem in my card somewhere?
type: custom:auto-entities
entities:
- LIST 1
filter:
include:
- LIST 2
exclude:
- LIST 3
card:
CARD_OPTIONS
auto-entities takes LIST 1, adds LIST 2 and removes LIST 3.
Then it adds this to CARD_OPTIONS, and thatās what youāll get in your card.
Thanks for your reply, but is that not what Iāve done in my auto-entity card above?
Are we able to filter using time
and date
I want to be able to only show the current sensor, for this sensor, thanks
After some of the latest updates this code does not work as a separate card:
card:
type: entities
title: auto-entities (sort name global)
entities:
- entity: sensor.ac68u_devices_connected
name: ŠŠ¾Š“ŠŗŠ»ŃŃŠµŠ½Š¾ ŃŃŃŃŠ¾Š¹ŃŃŠ²
secondary_info: last-changed
- type: section
filter:
include:
- domain: device_tracker
attributes:
source_type: router
options:
unique: true
sort:
method: name
reverse: false
ignore_case: true
Moreover - it forces some other cards to disappear.
How to reproduce:
Yes, I have the same issue when using mini-graph inside auto-entities. Somehow everything on the page inside the same layout-card is gone. Happens on all my pages where mini-graph is present. Other pages work fine. On 1.7.0 all works. I hope itās fixable.
Thereās a bug in auto-entities which can cause this. Iām working on it right now.
Does anyone have problems with disappearing cards that are not in layout-card or vertical-stack-in-card?
not disappearing, but appearing gaps around the auto-entities card (in stack-in-card): š¹ Auto-entities - Automatically fill cards with entities
using the hui-element card on the auto-entities card fixes that for now.
Here 3 cards:
- title: zzzzzzzzz
path: zzzzzzzzz
badges: []
cards:
- type: 'custom:auto-entities'
card:
type: entities
entities:
- entity: sun.sun
- type: section
filter:
include:
options:
unique: true
sort:
method: name
reverse: false
ignore_case: true
- type: entity
entity: sun.sun
- type: entities
entities:
- sun.sun
- sun.sun
This should be fixed in 1.8.3
Thomas, thank you! Now it works, I do not see the problem.
fwiw, š¹ Auto-entities - Automatically fill cards with entities is still happening.
Fwiw @Mariusthvdb this has been happening as long as I can remember with conditional cards in vertical stacks too.
conditional cards do tend to take spaces, even as separate cardsā¦
my issue above however is new since this week, and I believe it to coincide with the many updates of auto-entities. I didnt notice it after updating Ha itself to either of the 2021.3 versions (but might be wrong there, just didnt notice it)
Nothing else in that card config changed. thereās an older post of mine here too show the gapless way it was before:
This problem still exist since 1.8.2 and did not resolve with 1.8.3
Canāt reproduce with 1.8.3. What does your browser console say?
Your issue sounds like what my issue was. For me 1.8.3 has fixed it. Make sure you clear caches and reload page a few times. Sometimes it can get stuck to older version in the browser, even after multiple reloads. Closing other browsers can help. Or uninstall card, delete from resources, reboot HA, install again and add as resource, restart HA again and then reload browser.
Make sure it says this in your browser console, keep trying till it does and then test it.
